Upgrading Lighting
Old Sep 14, 2006 | 12:27 AM
bob howard's Avatar
bob howard
Default Upgrading Lighting
Just got my 96 Convertible, everything is fine, but the lights are nothing like my S2000. Yea, Honda has HID lighting. I was considering converting the 96 to H4. Would appreciate any help regarding the best brand to use. Also, has anyone upgraded their C4 to HID lighting. Thanks for your assistance.
Old Sep 14, 2006 | 12:34 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I nice upgrade for much less than HIDs is to install Sylvania Silverstar bulbs.
Old Sep 14, 2006 | 01:13 AM
Natas's Avatar
Natas
I have Hella H4's in my vette but they aren't that great. IMO the best non hid bulb is Osram Silverstar. Osram is different division than Silvania and has better bulbs but they're hard to get. Check out Ebay as they're only available in Europe and ebay has great prices. (there are a few places in the US that have them but I can't remember the names)
I bought a set of H1's for my bimmer, they're as close to HID you can get, very very white light and isn't ricey blue.
Old Sep 14, 2006 | 01:25 AM
Corvette Kid
I'm thinking there's no difference as I just bought a replacement Silverstar for my Nissan today. It said Osram Sylvania on the package. Got it at Advance.
Old Sep 14, 2006 | 11:51 AM
bob howard's Avatar
bob howard
I had put SilverStar's in my 2000 Prelude. Within a week the low beams were out. The local dealer replaced them, no charge, but that set went out in 3 months. High beams were fine. Maybe I just got a bad batch, as the electrical system was fine, and the orginal bulbs were still working fine when I sold the car. They did provide much whiter light.
Old Sep 14, 2006 | 11:59 AM
zo1boy's Avatar
zo1boy
Whats your guys take on the halo headlights for the corvette?
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
There are two components to good C4 lighting: the lense/reflector assembly, and the bulb itself.
The best lighting is obtained by buying a name brand H4(Hella, Cibie, Marchal, Bosch, etc.) lense/reflector, and matching it with a 55/100, 80/100, 90/100, or 100/130 watt H4 name brand bulb (Philips, Osram, etc.)
Do not fall for gimmicks like 'blue' bulbs, halos, city lights, etc.
Do not fall for the "diamond-cut" crap!
Do not fall for the cheap JCWhitney no-name stuff.
If you aren't spending at least $50 per side, you aren't getting the best that you can.
Want to find out everything there is to know about lighting? Go to this website
http://www.danielsternlighting.com/tech/tech.html
read everything on it, and make a decision.
Good luck.
Larry
code5coupe
Old Sep 14, 2006 | 01:41 PM
flyinlow90's Avatar
flyinlow90
I have Street Glow H4's in mine.
Old Sep 14, 2006 | 01:51 PM
Impala Balko's Avatar
Impala Balko
I have Adjure Clear diamond H4 conversion Buckets with 10,000k BiXenon High/Low HID's installed in them. I love the look and performance of HID's you cant beat it and the difference is litterally night and day.
The Ignitor is in the balast so all i had to do was plug in the wires and fasten the balast to the framing of the flip up headlight assembly. I used zip ties and they appear to be doing their job.
All these Pics were taken before I had a chance to adjust them they are much better now. The beam before was aimed too low and was too focused in 2 areas now the beams are all spread out and they really light up the road real nice.
Old Sep 14, 2006 | 01:57 PM
Natas's Avatar
Natas
Osram Sylvania is one and the same company, within the US they use both Osram and Sylvania, outside the US its Osram. The Osram Silverstar is a clear bulb with Xenon gas boost to increase brightness up to 50% color is similar to standard halogen though it is slightly whiter. The Sylvania Silverstar is the same bulb but with an amethyst blue coating with 30% more light than standard halogen and 4000K light color which is comparable to Xenon/High Intensity Discharge Light Systems as seen on high end cars from Acura, Audi, BMW, Cadillac, Lexus, Mercedes Benz, Porsche to name a few.
Sylvania Silverstar is currently available in 9003/H4, 9004, 9005, 9006, 9007 & sealed beam sizes, the Sylvania Silverstar is the Super White (blue/grey coated) version of the Osram Silverstar (clear) which is available in H1, H4, & H7. Osram Silverstar color is slightly whiter (very slightly) than regular halogen. We also have the Narva Range Power Blue bulbs are made in Germany and DOT compliant. The Osram Silverstar is E code (ECE Reg 37) but not tested for DOT compliance (FMVSS 108) since the bulb is made for the European market, but most likely meets US DOT standards if tested. All these bulbs are stock wattage so it will not have any effect on wiring.
Old Sep 14, 2006 | 03:07 PM
rocco16's Avatar
rocco16
According to experts, some of that is true, some is not. Go here to find out which is which:
http://www.danielsternlighting.com/t...good/good.html
Another interesting article on HID conversions from Stern's website:
http://www.danielsternlighting.com/t...nversions.html
You guys really should read his whole site. It's a wealth of information on automotive lighting. It will shed some truth on all the hype being shoveled around by people trying to sell junk out there.
Larry
code5coupe
Old Sep 22, 2006 | 12:11 AM
bob howard's Avatar
bob howard
Default Thanks for all your advice
Thanks guys, I ordered the Hella's today. Will run with "Silverstars" for the rest of the season, then convert to HID. Appreciate the help.
Old Sep 22, 2006 | 11:57 AM
Impala Balko
When you convert to HID make sure you re align your headlights because they will be off
Old Sep 22, 2006 | 12:17 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Doesnt matter what headlights I use
Cause I out run them anyway
Old Sep 22, 2006 | 02:58 PM
IrishJoker's Avatar
IrishJoker
READ STERN'S ARTICLE - HID IS A BUNCH OF HYPE!
Old Sep 23, 2006 | 04:04 AM
Goldcylon's Avatar
Goldcylon
Default re:Silverstars
I have silverstars in all my vehicles. Works great just make sure that you dont touch the bulbs when you insert them into the socket. Use a clean t-shirt or clean cotton cloth when you put them in the socket and make sure no oils (i.e. from your skin) touches the bulbs. According to the instructions its causes them to heat differently and may cause premature failure. Mine have yet to fail after almost three years of use. Goldcylon
To Upgrading Lighting
