Code 21 Tps
Old Sep 17, 2006 | 03:03 PM
ittybittyfds's Avatar
ittybittyfds
Default Code 21 Tps
has anybody replaced the TPS or adjusted it
if so can you tell me how to adjust
im not sure how to get the reading for the sensor
i know it should be .54+ volts but im not sure how to measure
my vette is idling very fast and the code i pulled was 21
Old Sep 17, 2006 | 03:45 PM
RRT vette's Avatar
RRT vette
http://www.se-r.net/engine/tps_voltage_adjustment.html
Once you get it around .54v, disconnect the battery to reset the ECM. If the code reappears you will need the FSM to troubleshoot.
