First to four bypass
Old Sep 18, 2006 | 06:07 PM
Huntervangolf's Avatar
Huntervangolf
Default First to four bypass
Who has installed the first to four bypass in there car and is it fairly simple?
Old Sep 18, 2006 | 06:48 PM
clf93lt1's Avatar
clf93lt1
just unplug it , the kit is just caps to keep dirt out. or you can get it tuned out of the computer, that way the light dont come on.
Old Sep 18, 2006 | 07:15 PM
jserio's Avatar
jserio
O.C.
Mongo hate the 1st to 4th thingy.
Old Sep 18, 2006 | 07:55 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
The best 1st to fouth bypass is a spirited accelleration to over 2500 rpm. It's hardly an issue if you run up the rpms.
Old Sep 18, 2006 | 09:42 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Just blip the gas pedal and the light (and shift block) go away.
Old Sep 19, 2006 | 09:35 AM
AILERON's Avatar
AILERON
Yup...
I've only had it tried to outshift me a couple of times. You learn pretty quickly to pop the throttle enough to get you through the gate.
Old Sep 19, 2006 | 12:47 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The kit for the later C4's includes a built-in resistor that keeps the disconnect from throwing a code.
As far as installing the kit, the hardest part is lifting the car enough to get access to the gearbox.
Do it right; spend the $20 for the kit.
I love short-shifting and feeling that SBC torque....
Larry
code5coupe
Old Sep 19, 2006 | 02:32 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
I got the Lingenfelter kit
Very easy install
My skip shift would come on when I got behind another car and couldnt be helped
Hated it
Old Sep 19, 2006 | 02:44 PM
Scoob's Avatar
Scoob
Exactly. The kit is a waste of money.
Old Sep 19, 2006 | 04:45 PM
ALLT4's Avatar
ALLT4
Bryan Herter tuned mine out, haven't seen it since. I did get used to running up the Rs though and it didn't phase me too much. But sometimes the wife likes to drive the car and she had all kinds of problems with it. She doesn't drive it the way you have to to avoid the skip shift, now she can drive it and not worry about it.
Old Sep 19, 2006 | 07:30 PM
silentpoet's Avatar
silentpoet
Never actually seen it kick in. The light has come on, but it goes off pretty quick. Granted I have had it less than a week. Of course it has some mods, so the previous owner could have disabled the switch.
Old Sep 19, 2006 | 11:29 PM
obnoxus's Avatar
obnoxus
Mine is disabled,,,, and I um,,, RARELY see the light !!!!!!!
Old Sep 19, 2006 | 11:53 PM
Dads90's Avatar
Dads90
Default Bypass
I hate it when you come to a quick stop, see an opening and take off only to have it go 1 to 4 and bogg when you need acceleration. Will practice keeping up the RPM's. I would take off in second to avoid the whole 1 to 4 thing.
Old Sep 20, 2006 | 11:51 AM
rocco16's Avatar
rocco16
Why not just install the inexpensive kit, AND HAVE FULL USE OF YOUR GEARBOX??!!!
Larry
code5coupe
Old Sep 20, 2006 | 11:59 AM
Scoob's Avatar
Scoob
If that is actually happening to you then yes, you need to learn how to drive it. If you're trying to sneak in and fill a gap and you're bogging it down you're a traffic hazard.
Old Sep 20, 2006 | 12:00 PM
Scoob's Avatar
Scoob
Knowing how to drive saves you a couple bucks and you have full use of your gearbox.
Old Sep 20, 2006 | 12:20 PM
Fast Eddiz's Avatar
Fast Eddiz
There are instructions in Tech Tips on how to disable this feature.
Other-Tech Tips-C4-1 to 4
To First to four bypass
Old Sep 20, 2006 | 02:38 PM
Wildcat1's Avatar
Wildcat1
When a cop is behind me, I like to shift early....but not to 4th. I agree with rocco.
Old Sep 20, 2006 | 10:24 PM
Tommy T-Bone
Why ?
Old Sep 20, 2006 | 10:45 PM
Rathbone's Avatar
Rathbone
I'm surprised there are people out there who put up with that "feature". I disabled it in my TA back in the day, and my corvette already had the bypass when I bought it. It's so much nicer, I didn't think it was debatable. If you want a device to decide the way you drive then buy an automatic.
