horn problems
Old Sep 18, 2006 | 11:28 PM
W89's Avatar
W89
Default horn problems
ok horn never has worked since I bought my 84 in january so I get a horn relay push down on the horn it blows the fuse next to the relay (behind the info center ) does it again, again so I start looking on the drivers side their are two wires together one goes to the conection on the horn the other they had grounded it didnt look like its original undo the tape its been spliced I undo it and the horns make a somewhat noise and doesnt blow the fuse ? so question where does this wire go? it cant be a ground I dont think cause if you ground it the fuse blows?help me ! could this also be draining my battery down to ?
Old Sep 19, 2006 | 12:45 AM
bob howard's Avatar
bob howard
Default Horn Wiring
Just wondering if someone had an alarm or extra horn wired in at some point in that system. I found that the drivers side horn was gone !!! Guess the former owner wanted it for something. Look for some other splicing on the horn circuit. Good luck
