90vette AC problems
Old Sep 21, 2006 | 09:21 AM
shenobi's Avatar
shenobi
Default 90vette AC problems
I bought my 90 vette about a month ago and recently I have started having problems with the AC. It has the automatic climate control. Here is my problem. About every other day when I turn on the AC the light above it flashes for about a minute and then turns solid. Once it turns solid the ac does not work anymore. After reading the manual, it told me to reset it by removing some of the fuses and that I may need to take it in for service to dix the problem After I pull the fuses, the ac will work again for about a day and then the same problem happens again. Do you guys have any sugggestions as to what the problem may be. I tried the search function but couldn't really find any help. Also, I an not throwing any codes.
Jody
Old Sep 21, 2006 | 09:54 AM
Scoob's Avatar
Scoob
Probably a low refrigerant situation.
