HELP w/ SAGGING Headliner
... took mine out of another vette (? yr.)...what i did is get a rather flexible putty knife and some paint sticks and start to lift the liner from the roof....
....as you do this, grab a paint stick or two to prop up under the sections that you lifted....i used my hand for the most part between the headliner and the top so i could feel how much resistance the insulation of the headliner was giving me so that i could carefully work around it to loosen it up....
...you are gonna itch for a bit like i did because of what i believe to be fiberglass.......once i removed the headliner from the donor car, i repaired the loose fiberglass with some 3-m spray adhesive (the heavy duty stuff) and put on a new backer-board and went from there...
....in your case, i mention the above so that you don't mangle the headliner.....you may be able to carefully peel the headliner material away without much damage and replace it with similar material that could be found at a fabrics shop......then, apply the new cloth where the old one was with 3-m and let it dry.....then you can fasten the backer-board with the new material back onto the "roof"...i would NOT use wd-40!....
.....there have been a few guys whom have taken foam and cut it to size, covered it as above, and fastened to the top and it looked quite well......as for me, something like that would not have the insulating qualities i need here in florida as the top gets extreemly hot!.....
