Condenser Shield
Old Sep 21, 2006 | 08:11 PM
Poncho C4's Avatar
Poncho C4
Default Condenser Shield
Well today I had some time to install a much needed
shield for my condenser on my 84! your opnions????
Before
After
Old Sep 21, 2006 | 10:21 PM
87vette's Avatar
87vette
Looks great!
Old Sep 21, 2006 | 11:43 PM
goldeneye_vet's Avatar
goldeneye_vet
Looks good. Now for the details please?
Old Sep 22, 2006 | 07:41 AM
Da Mail Man's Avatar
Da Mail Man
Old Sep 22, 2006 | 05:31 PM
Poncho C4's Avatar
Poncho C4
I used 1/8" diamond shaped aluminum grating sheet painted black
cut it 10"HX29"L held together by the two screws that
are in the back under the center bar on each end!
and I drilled three holes to the bottom of the front
bumper, using the the kind of screws that have the
plastic sleeve and also good size washers to hold it
in place, which were painted black.
P.S when you drill the holes you stick the sleeve in
the hole, then you put the screw along with the washer
and while you tighten it the sleeve seperates and holds
on to the bumper! I think you can also use steel sleeves!
I used the plastic ones cause those are the ones I had.
I hope that help's...........PONCHO.
Old Sep 22, 2006 | 05:39 PM
Jet-Jock's Avatar
Jet-Jock
How the heck do you get in and out of the car when it's in the garage like that?
Old Sep 22, 2006 | 05:58 PM
Poncho C4's Avatar
Poncho C4
Very carefully!!!!!
To Condenser Shield
