Strange "Knocking" Sound
Old Sep 22, 2006 | 10:04 AM
beachrover's Avatar
beachrover
Default Strange "Knocking" Sound
I drove the vette to work this morning and while sitting at a stop light I noticed a "knocking" sound. When I accelerated to pull away, it went away. When I got to the office, I noticed that I heard it as as soon as I opened the door to get out of the car. I raised the hood and couldn't hear anything coming from the engine bay. I walked back by the drivers door and bent down and it sounds as if it is coming from under the car just in front of the drivers door.
Any experience anything like this before?
Old Sep 22, 2006 | 10:21 AM
ghoastrider1's Avatar
ghoastrider1
check you oil pressure at idle,does it drop a bunch? like way to much? like almost zero? if thats the case,its rod bearing(s) knocking on your wallet.Hope its something else,something cheap.Put it on a lift at idle,find out where its comming from. Also need more info,heck,it could be a exhaust pipe hitting the frame.
Old Sep 22, 2006 | 10:26 AM
beachrover's Avatar
beachrover
Checked oil pressure at idle and it appeared normal. I know it doesn't matter but the engine has 55,000 miles on it.
Old Sep 22, 2006 | 02:05 PM
beachrover's Avatar
beachrover
OK, I went out to the parking lot and started the car. I drove it up the road about 3 miles and back. When I parked it I could hear the noise. My oil pressure was fine while driving and was hovering bwteeen 10 & 20 lbs while idling. I slowly pushed the accelerator down and the speed of the sound would increase but not to the same speed as the engine RPM's if that makes since.
Old Sep 22, 2006 | 02:09 PM
RRT vette's Avatar
RRT vette
On a 85 vette I had I could hear a knocking sound that didn't match the RPM of the engine. Mainly I could hear it at idle and when accelerating I didn't hear it. Seems I could hear it on the passenger side more. It turned out to be the flywheel. Just an experience post. Hard to say if we cannot hear it.
Old Sep 22, 2006 | 02:20 PM
mikey whipreck's Avatar
mikey whipreck
On my '85 I had a knocking sound when I got the car.
I would hear it at idle, only after the car was warm, then it would disappear when I was moving. It sounded like it was in time with RPM's. I got under the car while it was running to pinpoint the noise- turned out to be coming from the (only) cat. Fun part was, the cat also puked into my mufflers.
Old Sep 22, 2006 | 02:58 PM
beachrover's Avatar
beachrover
This sounds exactly like what I'm hearing. I hope it is only the cat or something of that nature. I'm going to try to take advantage of the local stealership; the sales manager has been calling me almost weekly ever since I had mine in to have the Optispark replaced wanting me to trade it in on a C6. He called again about an hour ago so I'm going to stop by this afternoon and pretend to be interested in the C6 and ask him if he would have the corvette mechainc just listen to mine while I test drive the C6. Knowing them, they'll tell me the engine is blown.
Old Sep 22, 2006 | 05:32 PM
ghoastrider1
hopefully,its something simple and cheap..like exhaust system knocking against something. flywheel/converter noises make a knock as well but ususally increase as rpm increases,but not always. best of luck.
Old Sep 22, 2006 | 06:23 PM
Skrud13's Avatar
Skrud13
Default Same deal
I just posted a thread about this in the Tech section.....I have the same knocking, so I put it on a lift and sure enough, both the drivers side pre-cat and the main cat are ticking/knocking loud. If you get under it, you will be able to tell if that is it.
Old Sep 22, 2006 | 06:44 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
If you have a 6sp ZF trans, see if it goes away when you put in the clutch. ZFs are noisy! I heard the same exact thing you described an hour after I bought my Ruby 7 years ago. I paniced because I thought it was a rod knock. 65K miles later and never a problem
Old Sep 22, 2006 | 08:43 PM
beachrover's Avatar
beachrover
Stopped by the stealership on the way home. I guess I should be nicer, the corvette mechanic there is actually very good and great to work with. Anyway, he stopped working on the car he had in the bay and came out to give it a listen. He even took the car out and we drove it around for about 30 minutes. He said that if he had to guess he would put his money on a cracked flywheel but wouldn't rule out a lower end problem. He said that there was a slight chance that it could be the cats but it didn't have the "right" sound to him. He said he was going to put it up on the rack Tuesday and look at the flywheel first. If that was fine he'd drop the oil pan and get in and look at the bearings. He said that if it was his car and the bearings were shot he'd never spend the money to fix them, he just buy a short block.
(edit: I forgot that at the end of our drive he had me "power brake" the car so he could hear it under load. As the RPM's increased to about 3,000 RPM's the "knocking" stopped. I then brought it back up to about 3,000 RPM's under load and then SLOWLY backed off the trottle. The knocking would start back at 1500 RPM's every time. He sai dthat if it was the lower end it should knok even at higher RPM's and thus why he thinks its the flywheel.)
Old Sep 26, 2006 | 10:06 AM
beachrover's Avatar
beachrover
Follow up: Mechanic just called and it was the main CAT. Flywheel, bearings all looked fine. He said that when he unbolted the exhaust rust spilled all over the floor.
Old Sep 26, 2006 | 10:21 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Hopefully, that's a rather inexpensive fix compared to a flywheel. Good to know the end of the story.
Old Sep 26, 2006 | 10:38 AM
beachrover's Avatar
beachrover
I guess all things being equal, almost a grand.
Old Oct 2, 2006 | 11:26 AM
beachrover's Avatar
beachrover
Default More Issues
Picked the car up on Thursday, no problems. I drove back to my office & parked. When I went to leave it was hard to start, not terrible but just had to crank it a couple of times. I figured maybe something to do with new CATS but couldn't figure out what. Friday morning, car starts fine. Saturday, wifey goes to start the car and it won't start. I go out and it would start if I would "slightly" hold the accelerator down just a bit but would cut off as soon as I let the RPM's drop below 1000. I got it to start again, held the RPM's at 1000 for a couple of minutes, it will now hold idle. I shift into reverse and it "chokes" off. I restart, hold at 1000 RPM's for 3 or 4 minutes, shift into reverse, no problems. I take it out for a quick spin and it seems to be running slightly rough. Also, very strong smell of gasoline while starting and while holding at 1000 RPM's.
Any ideas?
Old Oct 2, 2006 | 11:39 AM
USAFPILOT's Avatar
USAFPILOT
Now is a good time for some high flow cats, maybe some long tube headers, if your spending that kind of money get some better parts than original.
Nice avatar! She someone special?
Old Oct 2, 2006 | 11:56 AM
beachrover's Avatar
beachrover
Did install high flow cats but not headers.
Tera Patrick
To Strange "Knocking" Sound
Old Oct 2, 2006 | 12:01 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Im thinking if you reboot the computer it will be fine
It is used to the exhaust restriction and now it is gone
You could need O2 sensor(s) also
There is a way to do it but disconnecting the battery for a few minutes will do it too
Old Oct 2, 2006 | 08:03 PM
beachrover's Avatar
beachrover
Took the car back to dealership. They called this afternoon and wouldn't you know it, they say it starts and runs fine. They said there are no codes stored or anything else they can find wrong. They asked me if possibly I had "bad gas". I told them the car was starting fine before the changed out the CATS and I haven't put any gas in it since then. I told them to keep it over night and try it again in the morning.
Old Oct 3, 2006 | 03:52 PM
beachrover's Avatar
beachrover
"Service Advisor" just called. They did have difficulty starting the car this morning. They checked the fuel pump, injectors, vaccum lines, gaskets no problems could be found. Reset ECM, drained gas tank and refilled tank, no problems. Finally an old retired mechanic comes in and ask them if they've checked the trottle body. They pull it off and bingo, "dirt" and various other build up. Said they will clean it up & reinstall in the morning.
Sound like this could be the problem?
