pulley/damper question
Old Sep 23, 2006 | 11:35 AM
alby53's Avatar
alby53
Default pulley/damper question
i was wondering if the motor on a 94 has to be raised to get the pulley/damper off.it looks like not much room between the pulley and the frame.
Old Sep 23, 2006 | 01:16 PM
fredk's Avatar
fredk
No, it does not. But if you are installing a cam you have to loosen the motor mounts and slightly jack up the motor.
Fred
Old Sep 23, 2006 | 02:19 PM
Hotred94's Avatar
Hotred94
It's a two piece hub; undo the three outer bolts and the ring comes off, undo the center bolt and the center piece comes off.
To pulley/damper question
By Michael S. Palmer | 2026-06-03 09:39:05
