Idle Problem? Update--
Old Sep 23, 2006 | 08:43 PM
94redrag's Avatar
94redrag
Default Idle Problem? Update--
Since returning from Funfest my car is running weird.
Whenever I slow down for a stop light, the idle drops down to about 500rpm for about 15-20 seconds then it jumps back up to a normal idle. This only seems to occur after the car has been under a load. If I just run the rpms up while sitting in the garage it returns to a normal idle.
Any suggestions where to start, before I go cleaning the throttle body and IAC pintle for nothing. Its a 94 M6
O.K. after cleaning the IAC and throttle body, no change, even a little worse. Will hardly run after sitting overnight. I have noticed that the volts drop way down when coming to a stop as described above. The colts will drop down as low as 12.8 on the readout and the slowly climb as the idle returns to normal. The volts hold at a steady 14.3 -14.5 whenever your cruising along and the car runs well. Its only when you slow down for a stop.
Could I have an alternator or a battery going bad? How much would a bad alternator affect the idle quality? I'm open for suggestions!
Thanks, Zane
Old Sep 24, 2006 | 12:13 AM
94redrag's Avatar
94redrag
Anybody?
Old Sep 24, 2006 | 12:42 AM
vettes4fun's Avatar
vettes4fun
Take some carb cleaner and spray around the intake see if the engine rpm's change, sound like you have a vacuum leak.
Old Sep 24, 2006 | 10:49 AM
redwing76's Avatar
redwing76
Have your charging system checked. Start there. Once thats outa the way you can look elsewhere.
Old Sep 24, 2006 | 12:16 PM
94redrag's Avatar
94redrag
If its a vacumn leak, wouldn't it do it all the time? Not just at start up and when slowing down for a stop.
To Idle Problem? Update--
