Is there any hope on removing etched in water spots on my paint ? I have tried distilled white vinegar, bug and tar remover, Mothers Polish, Dupont med. rubbing compound and Mothers clay bar. Nothing works. I suspect that I know the answer. Costly paint job ! If any of you experts have an answer, thanks in advance.
Color sanding and buffing should take care of the problem, assuming the paint is okay. Unless you'e done it before, you might want to take it to someone. Still ALOT cheaper than new paint.
I use a synthetic clay bar, Chemical polish, aluminum oxide compund micro polish and that does the trick. If its real nasty, I have some stuff that a private chemist makes that does the trick every time, but dont ask, I dont know whats in it and I cant get anymore of it.
