How about some bonus points if you're both older than 50 and you WERE able to insert tab A into slot B?
and Ibuyvettes also,
I scored 4, and this is my second project turned-into-a-driver vette.
Does replacing the valve cover gaskets (bad leaks on both cars) count as anything? How about ripping the upper manifold off and polishing it?
I'm going to award myself the Bogus trophy though, because I redid the interior leather,carpets,and Halo.
Hmmm... an easy 8 but I also want to know if having the ZF Doc rebuild my trans makes it 9, it did involve a pallet/blocks/strapping, truck shipping & a single mass flywheel/clutch after I rebuilt the engine. Also that procharger install & custom fab alch injection should be at least 1/2 point?? What about welding in the roll bar & grafting a roadster x-brace underneath? All in my garage no less.
Been there done that! But must admit I've probably had a few more years to accomplish all 10 then some forum members and some of these items were a lot easier to do on a C-2/C-3 then a C-4.
I'm still a rookie with 1 point, but most of the stuff I did wasn't on the list, liike replaced exhaust, replaced headlights, replaced seat tracks, etc...
the trans rebuild
the engine rebuild (provided you assembled and R&R'ed each)
heater core replacement
radiator replacement
spark plug replacement (LTx only)
Even three-pointers:
put in 4.10's yourself (and they lived...)
installed a super/turbo charger yourself
replaced the foglight lenses
replaced a power antenna
