A-Arm dust shield....do they work??
Old Oct 1, 2006 | 09:29 AM
LannyL81's Avatar
LannyL81
Default A-Arm dust shield....do they work??
Was thinking about getting a pair of those aftermaket A-arm or inner fender dust shields, the ones that have slots in them for the upper A-arms. Do these work? Or do they get torn up from A-arm travel? Anyone have experience with these?
Old Oct 1, 2006 | 11:06 AM
Chewch87's Avatar
Chewch87
I put a set on my 87....I don't drive in rain or snow....so they are not really put to the test. But they do seal off the area nicely. Also they make the compartment look "cleaner" ..more complete. Very cheap and easy to install. There are two types.....I got the cheaper "rubber" types offered. I forget what the other material was. -
Old Oct 1, 2006 | 11:17 AM
Wayne88's Avatar
Wayne88
I may be wrong, but they look like they keep heat from escaping the engine compartment.
Old Oct 1, 2006 | 11:23 AM
Chewch87's Avatar
Chewch87
I considered that...but there seems to be plenty of airflow going on under there...I have not had any increase in engine or coolant temps...so if it does restrict the airflow...it must be minimal.
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I have a set and like them. Keeps the road grime out of the engine compartment and vice versa. As for heat, it appears that Wayne88 has a point. However I've not seen any temp changes after installig them.
Old Oct 1, 2006 | 01:50 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
they look good
Old Oct 1, 2006 | 03:27 PM
Da Mail Man's Avatar
Da Mail Man
Old Oct 1, 2006 | 03:54 PM
Deacon's Avatar
Deacon
I have the rubber ones on my '90. They keep the engine compartment clean even when driving in the rain. I like them better than the hard plastic ones. I tried the hard ones, but didn't like how they fit. I have had the rubber ones for about four years now and they still look good when they are clean.
Old Oct 2, 2006 | 09:36 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
I have them on my '88 Z52 coupe and they work well with no perceptible increase in engine compartment temperature. I drive around 13k miles per year, and it made a big difference keeping things clean.
Old Oct 2, 2006 | 03:56 PM
Billy Stargazer's Avatar
Billy Stargazer
Hot dawg! They look nice. I'm gonna get me some:>)
Old Oct 2, 2006 | 04:39 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I have the hard plastic ones and they seem to do a better job at keeping the engine clean compared to the stock ones.
Old Oct 2, 2006 | 06:37 PM
c4cruiser's Avatar
c4cruiser
Engine compartment heat is the enemy of underhood accessories like alternators. Because the alternator sits on top of the motor and doesn't get a lot of airflow from the radiator, the early alternators have a tendency to burn up internally because of excess underhood temps.
Most of the airflow thru the radiator goes downwards or out the holes where the upper A-arms are. If you block those holes, you are risking heat damage to the alternator. Not too sure how the A/C compressor would hold up as it isn't always working.
Old Oct 2, 2006 | 07:04 PM
JrRifleCoach
This is merely speculation on your part. My 86 has been running for 3+ years with these covers under many high temp conditions. Las Vegas cruises during mid-summer, running flat out in Nevada and other places unnamed. Plus countless other hi-temp situations for over 24,000 miles.
Not a problem yet. I'm convinced that these covers will provide a good debris barrier between the wheel wells and engine compartment. IMHO if you want to keep your engine clean, BUY 'EM!
Old Oct 2, 2006 | 07:54 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Nice Addition... Got to get me some of them during the winter...
To A-Arm dust shield....do they work??
