Battery tender
Old Oct 2, 2006 | 07:43 AM
BOWLING GREEN's Avatar
BOWLING GREEN
Default Battery tender
Battery tender. Where the heck do you mount one? Instructions say not to put it on top of battery. Only flat spot I found is up in the drivers side nose. Wires are too short to go to the battery. Could put in some butsplice and wire back to the battery. Any input?
Old Oct 2, 2006 | 09:06 AM
Billy Stargazer's Avatar
Billy Stargazer
I ran mine through the holes "gills" in the side of the battery compartment. I set the tender on a milk crate beside the car. Seems to work fine. This way it can easily be disconected if I want.
Old Oct 2, 2006 | 09:18 AM
Yakko's Avatar
Yakko
There was a thread about someone who ran wires from his battery through the gills, then connected his tender to those.
Old Oct 2, 2006 | 09:20 AM
shacky's Avatar
shacky
I just plug my Black and Decker version into the cigarette lighter. What could be easier than that?
Old Oct 2, 2006 | 09:47 AM
mikey whipreck's Avatar
mikey whipreck
I mounted my charger on the inner side of the battery (the side that faces the engine).
Old Oct 2, 2006 | 10:44 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
me too. then sit it on car cover on a box
Old Oct 2, 2006 | 10:45 AM
ejscarfo's Avatar
ejscarfo
I run mine thru the space on the inner fender. I don't have it set up to just "plug in", but it works fine for me.
Old Oct 2, 2006 | 11:05 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
I had my 86 going through the gills on the side
On the 94 I just put it above the wipers on the windshield and make sure the hood doesnt hit it when I close it
When I put it inside the battery next to the engine in front of the brake booster I worried about the heat and I didnt like the way the hood flexed when I closed it and it hit the trickle charger
Old Oct 2, 2006 | 01:39 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I laid mine on top of the driver's side front tire. Works fine. No problems.
Old Nov 4, 2006 | 07:52 AM
BOWLING GREEN
Default Mounted key word
Your the only one that got the key word < mounted > thanks for the input.
Old Nov 4, 2006 | 08:39 AM
Eyeguy77's Avatar
Eyeguy77
So far so good, I've had one on for 2 weeks and the battery has stayed fully charged.
Old Nov 4, 2006 | 08:48 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Some of us have the version that doesn't require mounting.
Old Nov 4, 2006 | 09:15 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I ALSO DID MIND THE SAME WAY. WORKS FINE!
To Battery tender
