Bose replacement
Old Oct 2, 2006 | 05:59 PM
zo1boy's Avatar
zo1boy
Default Bose replacement
In my 88 I have the stock radio and bose speakers. Well the speakers seem to be going out (they are crackling and whatnot.)
In the catalogues I've looked through, replacements go for $200 - $300 per speaker. Am i reading these incorrectly?
Is there a more reasonable replacement?
Old Oct 2, 2006 | 06:21 PM
bogus's Avatar
bogus
C4 Audio FAQ
Audio/Electronics Section
Old Oct 3, 2006 | 01:09 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
yarrrrrr not another one of these topics.
Everyone's advice will be: Ditch the bose system, get 6x9's for the rear, and (your choice or both) 4x6 for the dash and 6.5" (I think) for the doors and a head unit of your choice. You will be removing the stock radio and all speakers and micro amps mounted with each speaker.
Old Oct 3, 2006 | 01:36 PM
zo1boy's Avatar
zo1boy
sorry sorry, I know I should have searched, thanks for the input though.
Old Oct 3, 2006 | 02:17 PM
Laurel's Avatar
Laurel
just a tiny hijack here, you can't use the bose speakers with an aftermarket deck?
GIJoe's Avatar
GIJoe
its aight. we'll let it slide just this once
seriously though, do not past go, do not collect $200, do not bother replacing or troubleshooting the crappy bose system!
Old Oct 3, 2006 | 02:22 PM
zo1boy's Avatar
zo1boy
Well, I don't know TOO much about audio work, so i guess this project should be good for me in one respect.
Now I can put some real speakers in the dash.
Old Oct 3, 2006 | 03:12 PM
bogus's Avatar
bogus
why? the SQ won't change enough, and the noise more than likely will go up.
This is under the assumption they are available... there are some adaptors for the early bose systems, but I am not sure if they are for the speakers or the head.
Either way, the sonic quality of the 80s bose is poor at best.
Old Oct 3, 2006 | 03:31 PM
C4boy's Avatar
C4boy
You can, if you use a line level adapter on the head unit. I put an Alpine in mine in '99 and still have the factory bose speakers in my car. Still sounds like crap, but there's a slight improvement in sound over the factory deck.
Old Oct 3, 2006 | 04:33 PM
auto_cran's Avatar
auto_cran
Z01Boy -
I'm going to be doing the same thing to my 35th. Replace all the speakers with normal ones, and replace the stereo. I still don't know which stereo to go with ( I want to keep it as stock looking as possible). So far I am leaning towards this one:
http://www.mnrelectronics.com/pa16deambocd.html
Any one have any experience with it???
From my research, it doesn't sound too difficult of a project. I plan on using the same wire that is already used in the doors and the hatch area. Making my own adapter for the stereo shouldn't be too bad. Taking out the front door speakers sounds like the most challenging part.
Chris
1988 Chevrolet Corvette 35th Anniversary #1941/2050
1989 Pontiac Turbo Trans Am #760 (1800 miles)
1983 Delorean DMC-12
1985 Kawasaki Eliminator ZL900
Old Oct 3, 2006 | 04:49 PM
Laurel's Avatar
Laurel
The sound quality doesn't seem so low with the Bose speakers in there, just the crackles whenever anything on the deck gets touched. I assumed that would change when I put my Pioneer in there. I have a fantastic set of front speakers that I was debating whether to keep or sell, but didn't know what I should do as far as the rear speakers go, I figured I'd keep the Bose ones.
Old Oct 3, 2006 | 05:02 PM
AnniversaryJim's Avatar
AnniversaryJim
Originally Posted by auto_cran
Z01Boy -
Chris
Chris, I am about to do the exact same thing to my 35th Anniversary. I too would like to keep a factory apperance, but then again, there are so many other options out there.
My other thought is to replace the Crash Pad (breadloaf) with a flat dash replacement (there are a few aftermarket options here) and then mount a small widescreen display in it to watch DVD's on. This would obviously require the head unit to be replaced with an aftermarket single-din unit instead of a 1.5-din OEM looking one.
There is no doubt that replacing the 18 year old Bose speakers is a must.
Thoughts?
Jim
Old Oct 3, 2006 | 05:41 PM
GIJoe's Avatar
GIJoe
Why do you guys want to "keep it stock looking" for twice the price of a NICE head unit with a million options, better sound, Mp3 capabilities, etc?
I just dont get it.
Old Oct 3, 2006 | 05:53 PM
AnniversaryJim
I just dont get it.
Mostly because, like another recent thread put it, "I want a head unit that doesn't look like it belongs in a rocketship".
I like a clean, simple, functional head unit that doesn't have so many bells an whistles that you need an instruction manual to adjust the balance.
About the only real usefull thing I've seen recently is a head unit with a USB connector on the side of the faceplate that would allow me to pop in my 2 gig thumb drive with tons of my own, non skipping, music.
Jim
Old Oct 4, 2006 | 08:50 AM
auto_cran's Avatar
auto_cran
When it comes to this Corvette, I'm a purist - I want to keep it as original in appearance as possible. It' not a daily driver -heck - I'm lucky to get it out once a week. And when I do - the stereo usually isn't on. But I do want it working - like everything else in the car.
In fact, if I knew where I can get a perfectly good working replacement Bose headunit and speaker/amps without shelling out a fortune - I would probably go that route. But a good working unit for these cars seem hard to find, and $100 + for each speaker/amp is ridiculous.
Now if it was my daily driver, I think I would consider that ultimate sound system, with amps, subwoofers, etc...
Jim - your idea sounds cool - and there appears to be a lot of free space where the breadloaf is. The breadload on mine is staying where it is, though. While not the best looking thing (I seem to have to explain it to everyone that pops their head inside the car), I think its part of the car's mystique.
Chris
Old Oct 5, 2006 | 01:19 AM
AnniversaryJim
Chris
If I had a dollar for every time I had to explain the breadloaf, I'd be able to install the stereo of my dreams (which I haven't fully dreamed up yet).
I was looking around at some "headrest" style screens and was thinking that this approach would give me the cleanest look (mounted in the dash of course, not the headrest). I also discovered one that actually had a DVD player built in, but I don't think it would work because the disc is loaded from the top, and the overhang of the dash might be in the way.
If anyone has any thoughts or experience with this concept, please share.
Jim
To Bose replacement
