Outer window seals
Old Oct 2, 2006 | 08:56 PM
jmbatt's Avatar
jmbatt
Default Outer window seals
I know the door panel has to come off to install these, but someone said the mirror has to come off also...is this right?
Old Oct 2, 2006 | 09:14 PM
RRT vette's Avatar
RRT vette
No the mirror can stay on. The door panel comes off and you will need a rivet gun and proper size rivets and also a drill to get the old ones out.
https://www.corvetteforum.com/techti...D=63&TopicID=2
^ doesn't seem doable, to me.
Old Oct 2, 2006 | 10:21 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
I had to use a rubber mallet to "coax" my new ones into place. I agree I'd have to say that doing it without taking the door panel off is risky.
Old Oct 2, 2006 | 11:16 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Buy only GM parts, do not use the aftermarket ones, especially the Ecklers ones. They won't fit properly and are a bitch to get on without bending them.
Old Oct 2, 2006 | 11:55 PM
rrthomas1963's Avatar
rrthomas1963
Default piece of cake
i replaced mine took maybe 15 min after i removed the door panel. all i have to do is drill out the old rivits pull out the old seal and line up the clips and the holes and replace the rivits. then replace the door panels the it was miller time
Old Oct 3, 2006 | 12:10 AM
Demonic85's Avatar
Demonic85
15 minutes eh? why does it seem like it would take me longer cause everything does
Old Oct 3, 2006 | 02:40 AM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
I bet I can take any 15 minute job and make it at least 2 hours. I always seem to find a way to make it harder than it should be!
Kevin
Old Oct 3, 2006 | 10:35 AM
nickyg's Avatar
nickyg
I did the one on my drivers side door. I bought the aftermarket one's from M/A. Just make sure to use a stop on the drill about an eighth inch up so you don't find the drill coming out the outside of the door panel.
Old Oct 3, 2006 | 10:40 AM
nickyg's Avatar
nickyg
Here's the link from corvettemagazine.com that I followed. Excellent!
http://www.corvettemagazine.com/2001...ndow/win-1.asp
To Outer window seals
