Early C4 Codes Pulling
Old Sep 15, 2001 | 01:43 AM
Sonic's Avatar
Sonic
Default Early C4 Codes Pulling
There is a site out there that tells you how to do it and what the number of flashes mean. I need that URL, anyone have it saved? Link me up if you do, want to pull my codes tomorrow, TIA.
Old Sep 15, 2001 | 02:22 AM
WhiskeyPapa's Avatar
WhiskeyPapa
Default Re: Early C4 Codes Pulling (Sonic)
There's a communications terminal on the bottom right side of your driver's side dash...pull the cover off and connect the upper right hand pin with the one just to the left of it with a wire or paper clip. With your engine off turn the ignition key on....the check engine light will blink once, then twice. Then it will do that again, and then one more time. It will then blink out any codes (it repeats them once or twice in case you miss it) then at the end it will repeat the 1-2 code. I don't have the link, but I have a book, if you email me I'll try to get back to you with the error message.
Hope this helps
Old Sep 15, 2001 | 02:23 AM
WhiskeyPapa
oh yeah, my email address.....
markhager1@netscape.net
by the way....haynes manuals are great, lists all the codes and everything. I'd get one when you get the chance.
Old Sep 15, 2001 | 09:31 AM
OcalaGuy's Avatar
OcalaGuy
Try this link for information
http://home.fuse.net/c4/
To Early C4 Codes Pulling
