Tail light lense removal
Old Oct 10, 2006 | 09:53 PM
Rabbit1445's Avatar
Rabbit1445
Default Tail light lense removal
Does anyone know how to get the tail light lenses out of an 84-90 c4? Do you remove the backup lights then reach up through there? Also can you remove the side marker lenses?
Old Oct 10, 2006 | 10:22 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Yes and yes.
(I think I also reached up from the bottom). The installation looks nice but not particularly friendly!
Old Oct 11, 2006 | 10:39 PM
Rabbit1445's Avatar
Rabbit1445
Do the lights push in or pull out?
Old Oct 11, 2006 | 11:40 PM
Z51JEFF's Avatar
Z51JEFF
There is no easy way to get the lens out,what ever works.If you have big arms it only gets worse.Each lens is held in place by two 10 mm bolts.From the bottom up between the muffler and the bumper,like I said,what ever works.Its been awhile but if you get one out you can reach through the open hole and go from there.Once the bolts are removed they will come out from the front,towards you.
Old Oct 12, 2006 | 12:02 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default taillights
i had a burned out bulb. out comes the license plate, the backup light, the first tail light then the second one.
but it gives you a chance to check out the dirt accumulation behind the tail lights, and I washed mine out with a hose and soft brush
Old Oct 12, 2006 | 12:14 AM
goldeneye_vet's Avatar
goldeneye_vet
A ratcheting 10mm wrench is your friend. It isn't that bad of a job just time consuming. Oh and you might want to have health insurance to take care of the bumps, scrapes, bruises, and hemoraging that is known to have happened with such a job. Welcome to the world of the Corvette. It just gets better from here.
To Tail light lense removal
