Parking Brake light on
Old Oct 17, 2006 | 05:47 PM
Impala Balko's Avatar
Impala Balko
Default Parking Brake light on
I have a 94 6speed coupe if that makes a differance and now when i take my Parking Brake off the Parking brake light that says "Park" stays illuminated. What could be the problem and whats the fix.
Old Oct 17, 2006 | 08:28 PM
Impala Balko
Is there a sensor that plugs into that assembly that reads weather the P brake is engaged. anyone experiance this
Old Oct 17, 2006 | 08:34 PM
5pinball's Avatar
5pinball
theres a switch your park handle engages, it could be out of adj. or bad. pullcover off to check it
Old Oct 17, 2006 | 08:37 PM
Impala Balko
can you give me an idea of what it looks like. there must be some sort of wire going to it right.
Old Oct 17, 2006 | 09:19 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
There's also a chance it's still partially engaged.
Look in owners manual. There's instructions for properly releasing it.
They made it that way so you can set the brake then put the handle down to exit the car.
If you'll raise the handle up until you feel a ratchet click then press the button and hold it while lowering the handle that should do it.
Old Oct 17, 2006 | 09:35 PM
5pinball's Avatar
5pinball
yes ther is a wire going to it and when you get your cover off , and raise and lower your handle youll see how it works..........skte dave....... didnt even think of that! wife still cant operate hand brake. i have to release it for her half the time!
Old Oct 17, 2006 | 11:00 PM
Muffin's Avatar
Muffin
Different view. After starting if my key does not return completely to the "Run" position the parking brake light stays on. Might check that if all else fails.
Old Oct 18, 2006 | 09:12 AM
Impala Balko
The key is definately returning to the run position and the P brake is deffinately off Ill take the cover off and take a gander
Old Oct 19, 2006 | 12:38 AM
Impala Balko
I fixed it... thanks.... the little tab that reads weather the ebrake is engaged or not just needed to be bent a little bit. Dont you just love those cheap easy 2 seconds fixes..... no more annoying bright red light
To Parking Brake light on
