So on my 90 whats the best wat to flusy the rad just checked the green stuff and only good for 5 below and don't know when it was changed last. Thanks guys Tbone
I have never actually flushed mine. I just let it cool down and drain the coolant. I then fill it with water start it up let it run a few minutes long enough to open up the thermostat then turn it off and drain again. I did this I think twice until the liquid that was expelled was clear. I then put in the required amount of coolant and water. Seemed to work for me.
Use the search icon on top of the page and put in "radiator flush". Its been covered many times and will be helpful.
First thing I did was to drain the coolant at the petcock valve on the bottom of the radiator so I didn't have coolant all over the driverway. Next I left the petcock valve at the bottom of the radiator open and put a hose into the tank by the firewall. I let the water run with the engine running and the heater on until all I saw was crystal clear water exiting at the bottom of the radiator. I repeated this several times because it was fairly dirty/rusty looking. It took a couple of hours to get it really clean. I then started to fill with my 50/50 mix unitl I saw it coming out the bottom of the radiator, then I quickly caped the petcock off. I continued to fill it until the firewall resivoir was almost full. I then used the bleed valve on the water neck to burp the air out with the engine running. This is probably not the textbook method but it worked great. Make sure you have someone keep an eye on your eninge temps during the process to be safe. You don't want it running too long at any point without coolant or water in it.
From: The reason time exists is so everything doesn't happen at once
Originally Posted by rickreeves1
First thing I did was to drain the coolant at the pebcock valve on the bottom of the radiator so I didn't have coolant all over the driverway. Next I left the pebcock valve at the bottom of the radiator open and put a hose into the tank by the firewall. I let the water run with the engine running and the heater on until all I saw was crystal clear water exiting at the bottom of the radiator. I repeated this several times because it was fairly dirty/rusty looking. It took a couple of hours to get it really clean. I then started to fill with my 50/50 mix unitl I saw it coming out the bottom of the radiator, then I quickly caped the pebcock off. I continued to fill it until the firewall resivoir was almost full. I then used the bleed valve on the water neck to burp the air out with the engine running. This is probably not the textbook method but it worked great. Make sure you have someone keep an eye on your eninge temps during the process to be safe. You don't want it running too long at any point without coolant or water in it.
I do pretty much the same thing, only once the water is running clear I let as much of it drain out as possible. Then I close the petcock and add straight 9 quarts of straight antifreeze (the capacity of the LT1 is 17.8 quarts) and fill the rest with water, burping the system after its full. I do it this way to ensure that I have a 50/50 mix. If I added a 50/50 mix there's no way of knowing how much water was in the system at the start.
