Bracket for Radar Detector
Just wanted to share my pictures....
I am going to paint it black. Should Look better.
I also need to wire it, but I am not sure how? Any suggestions?
It works great for the Bel....
Glenn
[Modified by GM_96LT4, 8:58 PM 9/17/2001]
What parts did you use? Anything else that might be helpful?
Looks like a great idea that can be adapted to any detector.
First you have to get into the mirror. Underneath are the two lights. Take these out.
Now pop out the glass part of the mirror. It is in a little frame. The frame is what separates from the housing. Don't worry if the glass and the frame separate. The glas is sandwhiched, not attached.
The switch in the mirror is mounted to one of the lights. It is a double pole double throw switch. If you don't know what that means, it's OK.The back of the switch, has 12v+ and 12V- on the two poles. Use a volt meter to test.
I also tested the output of the lighter adapter to determine where the + and - 12 volts were fed.
Then I took the RJ11 phone cord supplied with my Valantine and cut it longer than I needed. I stripped the two wires I needed and put a nice thin coat of solder on them to make the tips solid.
Then I routed the wire where the other wires enter the mirror. Now you will know why you need to pop off the glass frame part. It is impossible to snake the wire through without removing the glass.
I just pinched the soldered ends between the existing lug and prong on the switch. I broke the delicate wire tips several times and had to restrip and solder new tips. Give yourself 4-5 inches of extra slack on the wire when you start.
Then just snap it back together.
Pics:
[Modified by Jay Axson, 11:29 PM 9/17/2001]
[Modified by Jay Axson, 11:31 PM 9/17/2001]
You must have been the one with the original post.
I will give it a try this weekend.
Glenn
Yes, I did post this about a month ago. I actually ripped the thing apart last night and took the pictures for you. It was a nice distraction from the attack.
Jay
Sorry it has taken me so long to respond, I couldn't even get to this page or my email due to this virus...
I will post a picture of my bracket tomorrow.....
My **** is from Callaway...
Glenn
