355 or 383?
A modified ZR-1?
Your car ain't stock.
Sure... a modified zr1.. it's not gonna have anything I can't put in my car. How about yours?
it started out as a "regular c4".... using your words.
You are comparing apples and oranges. A 368 or 415 would leave you in the dust and probably still go 100,000 miles.
And it's going be bullet proof like an LT-5 too right?
No, you're running your mouth about regular c4's. Bullet proof? You go ahead and be bullet proof while I beat your azz to the finish line. If I wanted bullet proof, I'd buy an armored car. I'll settle for fast.
It won't be bulletproof as a LT-5 and you are dreaming if you think you are going beat a worked 368 or 415 LT-5 to the finish line.
I'm not running my mouth, I simply said I wouldn't spend that kind of $ in a regular C4. To me to spend $10,000 on a motor when most C4's are in the 10-15k range is stupid but hey its your money.
It's called an opinion which I am entitled to just like you are entitled to yours. Go sell your car and see what it is worth.....
Next fantasy?
Yeah, you make alot of sense.
You are making more HP off the bottle then a stock ZR-1 huh?
No ****, you have a bottle and you have dumped a ****load of $$ in your car that you will never ever see again.
Oh and I bet that motor will run forever too ..... NOT!
Truth be known he should probably buy a rougher ZR-1, do the plenum, injector housings, headers and a chip and he would be in good shape.
At least when he was done, he would get most of his money out of the car.
Oh and since you questioned it:
ZR-1 415
0-60 mph 3.6 seconds.
Top Speed 201.5 mph
Funny how you mouth off but you are not even sure what your car will run plus it appears it is not even setup right
You are not going make me post the thread are you
Get off the couch, put that 200 shot on your Zr1 and let's run.
I am not posting again as you are a clown.
ZR-1 415
Top Speed 201.5 mph
I don't even want to talk about how your motor is going pull at 100mph vs the LT-5
Wow, you have lots of fantasies. Irrespective of that, your freight train will be behind me as I pass the finish line at the 1/4... you lose!
Heck in your thread, you can't even figure out how to build your motor.
I'm sure its as good as a J.L. built 415 1/4 mile= 10.60
Perhaps you should start selling your motors, just don't let anyone pull up the thread where it shows you have no clue
