Car Acting Up!!!!
to take the Vette to work, when I tried to start her she cranked
a little longer but she started and she idled high around 1400 rpm then I notice the check engine light came on
well to make a long story short I ended up taking my other car.when I came home from work that evening I started her up and she startedkind of eratic but after a while she idled alright, also the check
engine light didn't come on this time!!!
so today I took her out for a drive and she idled rough!
also when I start her she'll die out unless I stay on the gas
and after a while she'll idled normal!!!
does anyone here know what could be wrong?????
Thanks in Advance.........Poncho.
Shawn
I believe you got two Idle air control valves that might be acting up, pull the codes before resetting them then post what you get, Damn where is CFI-EFI, he's the genius when it comes to the cross fire engine.
Shawn
the Idle air control valves ? and where the heck are
they at??? as you can tell I'm just learning how to
work on me vette!!!!
Thanks in advance Poncho.....
Try posting in C4 Tech, maybe that'll scare him up...
Also, if this doesn't fix the problem check the fuel pressure. Nothing screws with a crossfire as much as erratic fuel pressure.
took her to Auto Zone got her scanned and
she threw code 45 and code 33 !!
I changed the m.a.p. sensor and tried to
change the 02 sensor but it's real hard to
take off!! so I soaked it with W.D 40 and
I will try tomorrow, then I'll let you guy's
know if that fixed the problem???
this morning I had some time to finish fixing the problem
I had with my 84.
I installed both the map & 02 sensor's and then started her up
and the darn check engine was still on
so I go backunder the hood to check the vacuum hoses and "lo & behold"
there was a loose hose !!! so in asscence I didn't need
both sensor's, but I figured I might as well leave them on
as the old one's were probably the original one's!
now she is running better then before.
Thanks to you all for your advice.....Poncho
I would like more feedback on the IAC's on a 84 Corvette throwing a code. I didn't think they do, but JLeatherman says they do. I haven't seen any proof of this. I know on the later than 84 model C4's there is no code for the IAC. Anyone with a 84 Corvette know the truth?
