Change Oil Light
2015 C5 of Year Finalist
Originally Posted by 95VetteMan1
For some reason the change oil light comes on after I change the oil....any any answers...thanks Bruce
I just got the Corvette, and it did not have an owners manual with it..should be here in a couple of days..but thanks for the info..Learning something everyday about it..thanks Bruce
From: Why are there squished peanut butter cups in my underware?
-Turn on the ignition (do not start the engine).
-Press the ENG/MET button twice within five seconds
-Press and hold the GAUGES button for about ten seconds. Watch the "change oil" light, it will flash for the ten seconds. When it stays off, it has been reset.
Here's a link to the tech tip:
https://www.corvetteforum.com/techti...=255&TopicID=2
"Seeing as this question is posted every so often, I thought I would put it in the tech tips for easy access. It works both on my 91 and a friends 95. 1. Turn the key to the "ON" position, but don't start the engine. 2. Press the ENG/MET button on the Trip Monitor and release it. Then, within five seconds, press and release the ENG/MET button again. 3. Within five seconds, of Step 2, press and hold the RANGE (1990-1991) button or the GAUGES (1992-1996) button on the Trip Monitor. The CHANGE OIL light will flash. 4. Hold the RANGE or GAUGES button until the CHANGE OIL light stops flashing and goes out. When the light goes out, the Engine Oil Life Monitor is reset. This should take about ten seconds. If it doesn't reset, turn the ignition "OFF" and repeat the procedure. If you remember to follow the procedure after every oil change, you should never see that light again."
zo7 freak beat me by 2 min...................
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Originally Posted by DarkMatter
My oil light just came on too. Is the light triggered by miles since last reset, or can the engine detect "polluted" oil?
Originally Posted by onedef92
I think it's programmed to light after a certain number of crankshaft revolutions.
Thanks onedef92
Thanks everyone for the comments that you have commented on. Like I said earlier this is my first Vette and I appreciate the info in this forum.I'm sure I will have many more...Bruce
Cool. I just changed the oil after the initial break-in. Had the rebuild about 875 miles ago. Changed the oil after 550. Was wondering if the motor was able to "pick up" metal, or if it was a preprogrammed parameter.
Thanks onedef92
Thanks onedef92
