Opti-What?
Old Oct 24, 2006 | 01:50 PM
All2kool's Avatar
All2kool
Default Opti-What?
What's all the hoopla about OptiSpark? Is this an item that needs repacing often - just because it gets wet?
Old Oct 24, 2006 | 01:58 PM
aminnich's Avatar
aminnich
92-96 LT1/4s have it. Distributor located below the waterpump by some brilliant engineering. 95-96s are greatly improved due to venting.
Would you put the dist on your L98 on front of motor, below the water pump, and well hidden, hard to replace? Even Ford had better ideas than that.
Old Oct 24, 2006 | 03:57 PM
All2kool's Avatar
All2kool
Ford always put the distributor up front for easy maintenance as they knew their cars would be requiring weekly tinkering. GM always assumed we wouldn't be needing accessing to the distributor. But putting it below the Water Pump is just dumb. Perhaps the engineer coming up with that one had one bonghit too many.
Old Oct 24, 2006 | 04:11 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
LT5s are relatively cheap now and no OPTI
Old Oct 24, 2006 | 04:12 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
They were probably correct in their assumption. But what's ironic is that we very likely wouldn't have the dreaded opti-spark problem if they just had put it up front (if they could've) like a logical person would.
Old Oct 24, 2006 | 05:09 PM
zo1boy's Avatar
zo1boy
I'll take 2
Old Oct 24, 2006 | 05:35 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here is pic on an LT4. It is the tan object behind the lower pulley.
Old Oct 24, 2006 | 05:49 PM
Greg Gore's Avatar
Greg Gore
The reason for the Optispark is because of the LT-1's unprecedented high compression with today's low octane unleaded fuel. The engineers needed a system that updated engine management controls very quickly and while admittedly an interim technology the Opti met the requirement for that time. Where else it could go? By driving the Optispark at the front of the cam, timing is more precise than driving it at the back. The Optispark is a pretty good system so long as you are aware of possible trouble if it gets wet; especially with 92 through 94 models. The 95 and 96 updated version is connected to the air intake so that fresh air is always being drawn through it to keep it dry. Granted if you have a waterpump failure the Opti should be replaced but really how often do LT-1 waterpumps fail? It's not like we have to replace the waterpump every year. Waterpumps are cheap; instead of worrying over your Opti you could just replace the waterpump every 50 or 60K miles instead. Coolant should be flushed and changed periodically anyway.
Old Oct 25, 2006 | 01:32 AM
aminnich's Avatar
aminnich
Ron, I believe you took that picture at the NCM? Do you notice something wrong with that motor being on display there??
To Opti-What?
