c4 mystery
Old Nov 2, 2006 | 10:38 PM
saoco's Avatar
saoco
Default c4 mystery
anybody knows the location of a 92 c4 power windows fuse or relay??? by the way its not in the fuse box. thanks
Old Nov 2, 2006 | 11:55 PM
Ttime's Avatar
Ttime
I'm not sure. I know there are a few relays under the driver's side dash and by the battery.
Old Nov 3, 2006 | 10:08 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Many times there is more than one system on a fuse....the fuse box will not always identify all the systems on that fuse, you'll have to go to the factory service manual to discover which fuses control which systems.
Larry
code5coupe
Old Nov 3, 2006 | 10:44 AM
adestoy's Avatar
adestoy
The '90 manual says it's a 30 amp circuit breaker in the main fuse block. There are also electronic circuit breakers (ECBs) in each of the motors. If both quit at the same time though, my money's on the one in the main fuse block.
Old Nov 3, 2006 | 11:37 AM
Eyeguy77's Avatar
Eyeguy77
I have the 92 service manual at home, if you don't get an answer I'll check tonight.
Old Nov 5, 2006 | 01:27 AM
saoco's Avatar
saoco
sorry I took a while to answer back, work is killing me, but thanks for your help guys, I will check the 30 amp in the fuse box asap and report back with the results. to continue...
To c4 mystery
