I know this question has probally already been asked but just to be sure. I have the GREEN coolant in my 95 Corvette when I purchased it. The vehicle did not have an owner's manual, so I ordered and got one. In the manual it asked for the DEX-COOL(orange-colored, silicate-free)which is the best?
I like the green. Dex-cool does not like to be mixed, it will turn into jello.
Personally, I would keep the green coolant.
Just thought I'd throw this out to you. The owner's manual lists the GM coolant spec # as 1825-M in my 90's owners manual. That is a silicated coolant. The newer Dex-cool II(?) is an organic acid based coolant. The two chemical bases are not compatible with each other and in some cases the acid based coolants attack certain kinds of gasket material, causing the gaskets to swell where the contact is made.
I bought some, 1825-M, from a chevy dealer on line for my 90.
Your 95 and my 95 vettes came from the factory with Dex cool (orange) coolant. If it were MY car, I would flush every bit of green coolant out and replace it with Dex cool. Do not mix or you will have jelly coolant as stated.
I would steer as far clear of Dex-Cool as possible. The switch to green has already been made, and there is a possibility that buy switching back you will only create problems. If it isn't broken, what are you fixing? Just Google "Dex Cool" and you'll feel much better about staying green.
In addition, the green still very easy to come by and _every_ car parts store has it. If you were in a real pinch on the side of the road, the dex cool just might not be available on the AAA truck or whoever else is out there. At that point, you'll be forced to tow your vette somewhere or risk sluge in your coolent system.
I went to a local vette specialist-He told me he changed to green antifreeze and flushed the entire system for a few hours.The new antifreeze is compatible with most color antifreeze(prestone)
He also told me of a pending class action suit involving GM and dexcool.I do not know too much detail about this.I hope this helps you.
Long story short:
01 Grand AM 28K miles and a sludge ring formed in the reservoir bottle, switched to Prestone yellow jug, currently 70K no issues.
03 GMC 2500HD, 5K miles, same as above, switched to Prestone yellow jug, no issues.
When I flushed the above I drove the car with pure water, for two days, flushed with water drove another two days, then filled with Prestone in the yellow jug = Looks like Gatorade
As a side note, the Chevy dealer here switches to green, after of course a flushing with pure water when a complaint arises in regard to the dirty toilet bowl ring in the reservoir bottle.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Your C4 and Dex-Cool were designed to work together. Green is not compatible with the alloys and plastics in your engine.
THERE IS A REASON THAT DEX WAS THE RECOMMENDED COOLANT, AND GREEN WAS NOT.
How is it that we all think we know more than the car's designers?
GM also recommends high-octane gasoline for our Corvettes. Why don't we run #2 diesel instead?????? ...or Ocean Spray cranberry juice??!
Anyone recommending green coolant in a car made for pink doesn't know a whole lot about why there are different kinds of coolant.
(And these are some of the same guys who preach "If Mobil 1 is good enough for the factory, it's good enough for me!!" )
Dex-Cool was introduced as a coolant with extended life and what I was told (whether it is correct or NOT) is due to the formula to add life a possible side-effect that I have seen is sludge. I have done all the maintenance on my cars in my prior post and no other coolant was ever added to factory cololant. Besides Prestone markets that their yellow jug is compatible with any color anti-freeze, no exclusions. My thoughts are to never have Dex-Cool in any of my vehicles due to what I have seen personally seen.
I've had too many bad experiences with the orange sludge. I am now spending 1600 on a head gasket swap that could be related. I also was quoted a couple thousand to replace the entire coolant system which may have been related but ended up not being necessary. If it's already been mixed it may be too late. I would flush it completely and stick with the green.
Don't want to debate. Just my opinion. Everyone else is entitled to theirs.
Just google Dexcool and you will see lawsuits against GM. Among other things that say Dexcool is no better than the green coolant. In the future I will only change the coolant in my vehicles with what comes from the factory. I have had no problems with it.
My dealer said late '95. All of my other vehicles use G-05 without problems. My '99 used Dex-Cool and went through head gaskets two water pumps and a heater core which was covered by the warranty. The car had 20k on the clock. All maintenance was performed on time and by the dealer.
I'm not saying using green is the only choice or not to follow the manufacture spec. I just won't buy another GM until they improve or replace Dex-Cool.
My advise to the original poster is to call your local GM dealer to see if your vehicle falls under the manufacture date of the manual and if it requires green or Dex-Cool. Then you decide which coolant
I guess I'll add some fuel to the fire....MY 1995 Owners Manual states on page 7-45 under engine coolant.....
" 50/50mix of water and a good quality ETHYLENE GLYCOL conforming to GM specification 1825M"
My 95 has had the green stuff in it since new and 77,000 mileswith no problems....????????
Interestingly, my 1996 Owner's Manual says in the "Service and Appearance Care" section, page 6-25 and again in Part 'D' page 7-46 to use Dex-Cool "(orange-colored, silicate free)" coolant meeting GM Specification 6277M.
I've a 95 and my understanding is that they changed to Dex-Cool midyear so the early 95s are green and the late 95s are orange(Dex-Cool).
I've also wondered about which way to go and came to the conclusion that it doesn't really matter. I think the big thing is to change your coolant regularly (every couple of years). I think this is especially important due to the fact that most corvettes accumulate minimum yearly mileage. It always amazes me that you can find an owner who will religously change his Mobil-1 oil at 2999 miles yet is quite happy have the original coolant in his car ("I've only got 65000 miles on the car!") though the coolant is 11 years old!
The most important thing to remember is not to mix the different types of coolant as it causes a sludge to form. Also be careful that any person servicing your car knows of this.
I found if you need to clean the overflow tank- remove it from the car and place some gasoline and a few pebbles inside and shake. That cleans it up really easily. Of course take the necessary precautions as gasoline is highly flammable. Flush it well with water and let it dry out before replacing on the car.
