Headliner removal
Old Nov 4, 2006 | 11:07 AM
rwolak's Avatar
rwolak
Default Headliner removal
I've scanned the archieves and can't get a clear answer. Has anyone replaced a headliner on an '86 Targa top? Does any of the roof trim need to be removed and, if so, how is it done?
Old Nov 4, 2006 | 05:32 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I redid mine. Major PITA for me. You don't have to remove any of the plastic trim. I just grabbed the falling headliner and ripped it out. Then (should have used gloves) grabbed the insulation and ripped it out. Then used goo gone and acetone to remove all the adheisve. At this point I should have dropped it off at an upholstry shop. I then adherd a sound deader/insulator, then covered in vinyl. It looks better than it did before, but it's not great. I now found a great shop that I'm going to have remove the vinyl I installed, put a 1/4" foam pad and lay down new vinyl with red stiching.
Old Nov 4, 2006 | 05:40 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
In my 89 I just took a pocket screwdriver and tucked it back in and it seems to be holding fine. Took about 15-20 min, 2 beers.
To Headliner removal
