LT4 plug wires
Old Sep 20, 2001 | 12:50 PM
thedevl's Avatar
thedevl
Default LT4 plug wires
When replacing plug wires on an LT4, whose do you use. Factory, aftermarket, etc? Where to buy? I'm looking for the best set money can buy, within reason. I checked into the Nology Hot Wires, those guys are at about 300 bucks, a little much for wires--don't you think?
THEDEVL :reddevil
Old Sep 20, 2001 | 01:29 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: LT4 plug wires (thedevl)
Personally the stock wires are pretty damn good wires. :yesnod:
Old Sep 20, 2001 | 08:02 PM
No Go's Avatar
No Go
I really like the factory wires, but I won't pay the price.
I used red Taylor wires that look very similar(ends are formed different and no numbering). Got them from Summit mail order and cost 51 bucks. Part number 74225.
Good luck. (Thats for installing any spark plug wire on LTX type engines!)
Old Sep 20, 2001 | 10:17 PM
RichS's Avatar
RichS
Default Re: LT4 plug wires (No Go)
I use MSD wires on mine. Much less resistance than the OEM wires!
Old Sep 20, 2001 | 10:34 PM
bac22's Avatar
bac22
Default Re: LT4 plug wires (RichS)
The resistance is minor compared to the amount of voltage going through them.
Old Sep 21, 2001 | 08:26 AM
RichS's Avatar
RichS
Default Re: LT4 plug wires (bac22)
It might be minor, but all the little minor enhances add up after a while. Why spend good money on a lesser quality part!
Old Sep 21, 2001 | 10:05 AM
Hutch's Avatar
Hutch
As the others have said, the stock wires are really fairly decent. Their major drawback is price. Keep in mind the GM replacement wires you get will NOT have the cylinder numbers on them.
I think the Taylor Spiro Pros are a good value for the quality of wire and boots you get.
MSD are surely good quality wires, but more than one CF user has stated one or more wires were too short in the kits they bought. Maybe that's been corrected now.
Top of the line wires would have to include the Magnecor Race Wires, but these are custom order only and expensive. They have a great web site with loads of technical info at http://www.magnecor.com/.
Bottom line... as long as they are in good condition, are any of these wires likely to make a detectable difference on a stock ignition system? Doubtful.
Old Sep 21, 2001 | 10:48 AM
thedevl's Avatar
thedevl
Default Re: LT4 plug wires (gs633)
Thanks for the replies. Looks like there are choices.
Next question. Most of these manufacturers don't list their product for the LT4. Do I buy the one for the LT1?
THEDEVL :reddevil
Old Sep 21, 2001 | 11:17 AM
kbuicker's Avatar
kbuicker
Cruise-In I Veteran
Cruise-In II Veteran
I just had to replacce mine, apparently I burned through them(guess they touched the manifold) ran me a few $$$$$$$$! What crap! Runs like a champ now!
Old Sep 21, 2001 | 05:06 PM
thedevl's Avatar
thedevl
Default Re: LT4 plug wires (kbuicker)
Help me out here guys. Do you buy LT1 wires for and LT4. None of these mfgs shows an LT4 wire set.
THEDEVL :reddevil
Old Sep 21, 2001 | 09:52 PM
RichS's Avatar
RichS
I used the 95 part# for my GS. The only problem is the coil is differant on a 96 than a 95 so you have to make up a coil wire. This was with the MSD wires.
Old Sep 21, 2001 | 10:13 PM
JasonL's Avatar
JasonL
As Rich said, the wires are the same, the only difference is maybe the coil. I think the Taylors are supposed to fit all 92-96 C4s. They include two types of coil wires, so I'm guessing the one I didn't use is for the 92-95 style coil.
Old Sep 21, 2001 | 11:20 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I've got the OEM LT4 red wires on my 96 LT1 and they work great. :blueangel:
To LT4 plug wires
