LTPWS alarm
Old Nov 7, 2006 | 01:30 PM
dheiser's Avatar
dheiser
Default LTPWS alarm
I started getting this Low Tire Pressure Warning System alarm. It comes on after about 5 to 10 minutes of driving and stays on. The tire pressures are good (30 psi). When I bought the '94 'Vette acouple of weeks back, the Low Tire Pressure alarm came in along with the LTPWS alarm at the same time. I corrected the pressures which cleared the tire pressure alarm but the LTPWS alarm comes in now and stays on. Is this a problem that only can be corrected by sensor replacement?
Old Nov 7, 2006 | 03:45 PM
Red Dwarf's Avatar
Red Dwarf
The low tire pressure warning comes on if your pressure is 25 psi or below. You may have a cranky sensor? Have you tried increasing the tire pressure to 35 psi? I would try it & see what happens.
There is a procedure for determining which sensor is the problem. Are you familiar with the use of the data line connector for pulling codes.
