95 Bolt Pattern??
Old Nov 7, 2006 | 05:47 PM
dc3plt's Avatar
dc3plt
Default 95 Bolt Pattern??
Looking to get a new set of American Racing Torq Thrust II's.
I see they come in various bolt patterns but I'm not sure what mine is. 1995 Stock Vert.
Thanks alot everyone!!!!!
Old Nov 7, 2006 | 06:45 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
4 3/4" bolt circle.
Old Nov 7, 2006 | 06:52 PM
waterdogvette's Avatar
waterdogvette
Old Nov 7, 2006 | 07:32 PM
dc3plt's Avatar
dc3plt
Torq-Thrust II 2 - piece Polished Alloy, 5x4 3/4 single bolt circle, 32 mm offset, 6 1/2 "backspacing
Torq-Thrust II 2 - piece Polished Alloy, 5x4 3/4 single bolt circle, 46 mm offset, 7"backspacing
These are the wheels I'm wanting and this is the setup it shows.
Does this seem right? I do not know enough about the offset and backspacing. I really would prefer no mods to put wheels on.
Old Nov 7, 2006 | 09:08 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If I'm not mistaken, you want 56mm offset for the front.
You didn't give the actual widths of the wheels, but the backspacing seems to be OK.
I have 50mm offset on the rear with my 11" rims.(not ARE rims)
Old Nov 7, 2006 | 09:17 PM
c4cruiser's Avatar
c4cruiser
What wheel width are you looking at??
Offset is the distance from the wheel mounting flange to the centerline of the rim. backspace is the distance from the mounting flange to the edge of the rim on the inside.
56mm offset is correct for a 9.5" wide wheel. The backspace will be around 7.5" For an 11" wide wheel you can use a 50mm offset to keep the wheel inside the wheelwell. Backspacing on this wheel will be about 8"
Old Nov 8, 2006 | 04:30 PM
dc3plt's Avatar
dc3plt
Sounds good.
I'm looking at 9.5 for both but am considering the 11" for the rear.
Is the 11" the ZR1 width? If so what size tires do I need to look at for this?
Thanks guys, this is a huge help!!!!
Old Nov 8, 2006 | 06:59 PM
c4cruiser's Avatar
c4cruiser
The 11 inch wheel was the width of the rear wheel on the ZR-1 and the '96 Grand Sport coupes. The two wheels have different offsets (38mm for the ZR-1 and 50mm for the Grand Sport coupe).
This difference was because the rear portion of the ZR-1 body was wider than the standard C4 coupes; it was 3" wider at the rear end. A "real" ZR-1 wheel will bold on but it will extend out from the wheel well opening. The offset on the 11" GS wheel allowd the wheel to sit in the wheel well but the GS Still had a fender flare to cover the tire tread.
The Grand Sport convertibles used 9.5" wide wheels at all corners.
Having the same size wheels and tires allows you to rotate the tires for better mileage. The 11" ZR-1 and GS wheel used a 315/35 tire and the 9.5" wheel can take either a 275 or 285/40 tire.
To 95 Bolt Pattern??
