how do you remove the shift knob
Old Nov 8, 2006 | 06:06 PM
maxfli's5's Avatar
maxfli's5
Default how do you remove the shift ****
for automatic on a 86 thanks in advance
Old Nov 8, 2006 | 06:47 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
pop center cap with small screwdriver, remove ring clip, pull up and remove from shaft
Old Nov 9, 2006 | 03:00 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I use a #10 snap ring pliers to remove the snap ring ,after I very carefully pry out the shift **** at the rear first and then the front.
Old Nov 9, 2006 | 08:50 AM
maxfli's5's Avatar
maxfli's5
thanks guys
Old Nov 9, 2006 | 10:59 AM
Bob89c4's Avatar
Bob89c4
How bout for a Six speed?
Old Nov 9, 2006 | 12:20 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Almost the same, except there is no snap ring.
Remove the center cap, and you’ll see a “wedge” that is driven down into the shift lever. This wedge is next to impossible to just pull out. The easiest way to get this out is to grab it with a small pair of vice-grips. Then put a long screw driver or other long rod through a portion of the vice grips. This will then give you something to tap up on. It will take a few good hits to free the wedge. But once the wedge is out, you just unscrew the know.
Note: The wedge is keyed, so be sure and align it up correctly when re-installing.
Old Nov 10, 2006 | 06:58 AM
Bob89c4's Avatar
Bob89c4
Awesome! Thanks for the info RollaMo!
To how do you remove the shift knob
