Air intake kit- Does it increase engine sound when accelerating?
Nov 9, 2006 | 11:32 AM
Does adding an air intake filter kit increase the sound when accelerating (like on the older cars when guys would flip the round air cleaner lid over)?
Nov 9, 2006 | 11:44 AM
St. Jude Donor '05
Normally it does increase it. Most airboxes have some restrictive baffling in them to meet noise standards, they really serve no other function.
Nov 9, 2006 | 12:03 PM
Generally yes, you'll hear the intake sucking
Nov 9, 2006 | 01:22 PM
Remove stock baffles
Can the baffles be remove on a stock air box to increase performance/sound?
Nov 9, 2006 | 01:25 PM
Yes to remove, no to more performance/sound. Cutting the air cleaner lid open would make more sound, also sticking a filter on the TB would as well, but that may be bad for sucking in hot air. The full A/O intake kit has a quite a bit of sound.
Nov 9, 2006 | 01:39 PM
Quote:
Yes, cut a big square hole in the filter lid to expose the filter.
Its not quite as loud, and still benefits 5-10hp on an L98.
Nov 9, 2006 | 03:07 PM
So if I cut a hole in the lid of my 95, it wouldnt make the engine sound any more beefy, you would just hear a sucking sound?
Nov 9, 2006 | 03:36 PM
Quote:
Correct.
Nov 9, 2006 | 03:37 PM
huh. I wonder if that would be at all worth it. I prefer roar, not whoosh.
Nov 9, 2006 | 03:43 PM
Then change to a K&N filter. No, it will not add 20 hp, but sounds more like what you are describing. I went to K&N for just that reason.
Nov 9, 2006 | 03:46 PM
Quote:
You actually found a noticeable change in sound?
Nov 9, 2006 | 03:49 PM
Yup! Especially when it sucked in the neighbors cat.
I am not running cut lid, just the K&N and at WOT it is very audible.
Nov 9, 2006 | 03:50 PM
St. Jude Donor '05
Coming from someone thats always used K&N and aftermarket boxes Id just cut the stock lid, keep a paper filter and call it a day. It will run the same IMO and save you money.
Nov 9, 2006 | 05:18 PM
i had the k&n + home-cut stock lid gig, then threw it in the basement in a pile of other junk.
Nov 9, 2006 | 05:22 PM
I'm gonna get a Claw for mine. I know the performance gains are crap, but I want it for the sounds, and I think that it + smooth ducts would look nice in there
Nov 9, 2006 | 06:38 PM
Quote:
Why?
Nov 9, 2006 | 07:18 PM
Aaah but when you say "run" do you mean "sound"? Im not looking for hp gains, just the cool-sounding-factor.
Nov 15, 2006 | 07:20 PM
When I purchased my 96 LT1 it came with a 3 filter SLP cold air induction kit in place of the factory airbox. About a month after purchasing the car, I replaced it with a factory airbox with the K&N air filter. I did not notice much of a horsepower difference between the two but the car was louder in the engine compartment with the SLP kit. Both intakes sound good but the SLP definately gives the car a little more attitude.
Nov 15, 2006 | 07:43 PM
St. Jude Donor '05
Youll get the sucking sound you want. I mean...
Nov 15, 2006 | 08:11 PM
