headlight motor problems
Old Feb 9, 2007 | 05:59 PM
jhammons01's Avatar
jhammons01
Well I got my two gears today. Let's see if I can follow simple instructions. I transferred the above magazine article to a Word document. Let me know if any of you would like the file for your own purposes. I'll email it to you.
I'll take my own set of pictures as I do the job.
Old Feb 11, 2007 | 10:12 AM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Cool!
Let us know how it turns out.
Old Feb 14, 2007 | 06:43 PM
jhammons01's Avatar
jhammons01
Still looking at the gears........5 days later.
The Tools are still cold in the box, completely untouched. Yet my Self esteem suffers from the opposite.....completely crushed.
I'll get to it, maybe Friday.
Until then, I'm the C4 winking at everybody
Old Feb 15, 2007 | 02:20 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check the C-4 TechTips Section on this Forum for repair articles, too. Take your time. Not a hard job. If you can repair a clutch, you can do headlight bushings no problem.
Old Feb 15, 2007 | 03:22 PM
Bob89c4's Avatar
Bob89c4
This was the first thing I had too do to my C4 also. I guess its like a right of passage to C4 ownership?
Old Feb 21, 2007 | 01:26 AM
jhammons01's Avatar
jhammons01
Default May apply to '84s only.
Now I am pissed.
That article that found and transferred to this thread is ok for reference BUT Heed the following
On mine, There are 4 nuts and 2 Screws that hold the entire Headlight Frame onto the Hood. The article gets into all this detail about taking off this and that..........
......Just unhook the two Plugs (1 for the motor and 2 for the Headlight) Then advance the headlight so that it is open about halfway. remove the two Torx screws then the two Phillips screws and take off the Bezel. Then take off the bracket mentioned in the article
Then take off the 4 nuts and two screws with a 10mm and pull the entire Headlight assembly and place on your bench......MUCH EASIER!! This Headlight removal should only take 10 minutes tops.
Once on the bench take the motor loose from the Headlight assembly and place it aside. (I sound like Emeril) Take the 6-7 Phillips screws out of the motor and pry that sucker open.
Once the inside is repaired the reverse of the above is just as simple and should only take 10 minutes.
The Motor itself, once opened, the larger white gear was stripped. I just popped the new in place and put it back together.
Anyway, this job was in no way worth two weeks of procrastination over.
Old Feb 21, 2007 | 08:08 AM
runner140*'s Avatar
runner140*
Been there, several times.
Old Feb 21, 2007 | 08:23 AM
ThomasRetUSN's Avatar
ThomasRetUSN
I had the same thing happen to my 86 and I replaced the bushings (with brass bushings). No more problems. The instructions given here are the way to go. It is easier that you think. Good luck.
Old Feb 23, 2007 | 02:25 PM
Cadder's Avatar
Cadder
The 84-87 don't have bushings, just nylon gears that can wear out. They changed the design in 88 due to issues with the gears. The 88-96 are the only ones to have bushings. My 86 just started winking as well and I thought it was the bushings only to find out that mine doesn't have bushings. I'm going to the store this afternoon to return the bushings and buy the replacement gears.
I do know that you can buy brass gears instead of the OEM nylon gears for the 84-87, but it's $100 vs. $35 for both gears.
Old Jun 2, 2015 | 12:33 PM
terry50's Avatar
terry50
start the car. one headlight open up, the other one stays closed. took a while and the one that is open closes........wow
