94 LT1-tranny failed
Old Nov 13, 2006 | 04:54 PM
grayml's Avatar
grayml
Default 94 LT1-tranny failed
I had 165K miles on it so I can't complain.
Here's my options:
1. A GM rebuilt unit with a 3 year 100K mile unlimited warranty-$2800 installed within about 7-10 days.
2. A rebuild at the dealer ~$2K, 12 mo/12K warranty
3. A rebuild at a local tranny shop, $1700 with a 12/12K warranty
4. Buy the rebuilt GM unit myself for $1400, may take 3 weeks to get it or longer and the warranty is 12/12K if a local shop does it. The dealer wants $800 to install this (TOO much).
I had to get a rental car so time is a factor. Which option would you experts out there choose?
Old Nov 13, 2006 | 05:33 PM
IRAraid's Avatar
IRAraid
Default Trans Rebuild
I had a local shop do it for $1600 with a 12mo/12k guarantee. It was in and out of the shop in 2 days. That was 2 years ago and it is still strong.
The main thing I relied on was the recommendation of a good friend who was in the body shop/full reconstruction business (quick paint jobs on insurance jobs to C3 frame straightening for restorations).
I wouldn't have gone to a chain trans shop on a bet.
Go with your #3 if you can get a positive "inside the business" recommendation from someone in the business of serious repair.
Good luck
Old Nov 13, 2006 | 05:50 PM
rickneworleansla's Avatar
rickneworleansla
I had the dealer rebuild mine, summer 05, and added a higher stall torque converter and shift kit at that time. Everything is still running fine and it shifts much better. If I was to do it over I would get a transmission that could handle more power for my future plans. You may also want to add an external cooler to extend the life of the trans.
Old Nov 13, 2006 | 06:21 PM
Greg Gore's Avatar
Greg Gore
Ask around for someone who likes to do 4L60E transmissions and pull it out yourself and take it to him. Probably can have someone go through yours for a few hundred and retain the original that way. I wouldn't recommend a rebuilt because they are often assembled from a collection of used parts from 100 different transmissions with who knows how many miles on each part and I absolutely would not go near any so-called specialty transmission shop. A local Corvette club might be able to recommend someone reliable. For example, we have a guy who used to do automatics for a Chevy dealer before coming here and he loves them. He doesn't advertise looking for work but he loves to do 700R4's and 4L60E's. He also said they are extremely good transmissions. I plan to let him do mine just to have it renewed when I get some of this other stuff back together and finished up.
Old Nov 13, 2006 | 07:36 PM
MR.LT1's Avatar
MR.LT1
Only one person will rebuild my tranny whenever it goes.....
The Man, The Myth, The Legend, "PETE K"
Old Nov 13, 2006 | 09:44 PM
grayml's Avatar
grayml
Thanks everyone and Happy Cruising
Old Nov 14, 2006 | 12:46 PM
Redvette_22's Avatar
Redvette_22
If you go to a "local" shop for a rebuild, make sure you get your trans back and not one "from a rack". This was done to my daughter's corvette and they did not install a corvette trans. The shift points were off both normal and WOT shifting, but they would do nothing about it because...."it worked".
Old Nov 14, 2006 | 03:16 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
ZF6 or 700R4?
A ZF I would put in myself Not a 700
Old Nov 14, 2006 | 03:43 PM
Pete K's Avatar
Pete K
If it were my car, I would probably use the local shop. This assumes he comes highly recommended. Rebuild yours, new converter, toss a beast in it and beef up the 3-4 clutch pack. A local pro will know what these parts are and also recommend them.
Old Nov 14, 2006 | 06:55 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
um, um ,um, so what are you going to do? BTW, that suggestion re local Corvette club might also include NCRS chapter at/nearby in Wilmington. them guys is pretty particular......
Old Nov 16, 2006 | 01:44 PM
grayml's Avatar
grayml
I talked to a couple of GM mechanics I know that don't work at the local Chevy dealer where I'm getting the work done.
They said on the GM rebuilds with the 3yr/100K mile warranty that all new parts are put into these rebuilds and they are tested before shipping, and that is what they would get one even with the $1k difference.
I've heard other horror stories about chain and independant tranny shops using used parts and like was said above about putting in someone's else's old tranny, I've had a couple of bad experiences with a Mustang tranny rebuild.
Old Nov 16, 2006 | 05:13 PM
Pete K's Avatar
Pete K
I have been in transmissions that were remanned by gm. They do not use ALL new parts. They are very complete rebuilds though. Great quality, and even better warrantee. Of course, some folks have had troubles with them, no company is perfect.
The 1 disadvantage of a gm trans is that they are only available stone stock. A local shop can make improvements to you trans.
Old Nov 16, 2006 | 05:33 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'm not saying I doubt your friends, but I've seen a lot of engines that were "reman", and I'd say most, by far, don't use all new parts. Not ALL NEW, just things that need to be replaced and those that look ok are left alone.
WADR to your friends, I'd say PeteK is correct re the trans. The way to have fewer (maybe "no problems" is too hard to expect) problems down the road is to get it done. And done correctly with all new parts.
Your experience with the Mustang rebuild would teach me one thing: there are good shops, and there are bad shops. I found the bad shop; time to go find a good one. And if you found one bad one, it means the good ones are harder to find.
Old Nov 17, 2006 | 08:46 AM
grayml's Avatar
grayml
Being that my vette is my daily driver for now I went with the GM unit from the dealer, can't beat the warranty.
Even if they don't use all new parts that 3 year warranty is a little peace of mind until I can afford a C6
To 94 LT1-tranny failed
