Fuel Gauge Problem
Old Nov 18, 2006 | 08:49 PM
huxster's Avatar
huxster
1st Gear
Default Fuel Gauge Problem
Hi Gang,
Just bought my first Corvette. 1984 model.
Here is my problem. The fuel gauge always says it is full. Is it a problem with the sensor in the tank or the dash unit. The car runs great and has a greenwood body kit on it but it makes me nervous about running it out of gas somewhere.
thanks
Old Nov 19, 2006 | 08:01 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
...moved from the Help section and with a ttt
Old Nov 19, 2006 | 10:14 PM
mikey whipreck's Avatar
mikey whipreck
You're sending unit needs the fuel level float arm cleaned
https://www.corvetteforum.com/techti...=277&TopicID=2
Old Nov 19, 2006 | 10:44 PM
SunCr's Avatar
SunCr
I'd verify the wiring and dash first. Ground the sending wire and make sure the Dash goes to Empty. If not the wire is open or the Dash is the problem. Otherwise, the sending unit needs to be rebuilt or replaced.
Old Nov 20, 2006 | 01:00 PM
Frizlefrak's Avatar
Frizlefrak
The sending unit repair is easy. Drop me an email if you want the tech article in MS format with pics.
To Fuel Gauge Problem
