water pump question
Old Nov 18, 2006 | 09:59 PM
JH23's Avatar
JH23
Default water pump question
buddy of mine has a 93 like mine,just not a ruby...we looked up under his car tonight and saw a few drops of antifreeze....if its his water pump leaking...where will it be coming from ...its on the cross member under the bottom of the car...where should we look to see 100% if it is the pump?
Jamie
Old Nov 18, 2006 | 10:02 PM
Strick's Avatar
Strick
There is a weep hole under the water pump. You can also see anti freeze sprayed on the inside of the hood. Fix it fast as you can lose the opti if it gets wet.
Old Nov 18, 2006 | 10:14 PM
JH23's Avatar
JH23
theres not any on the hood anywhere.....i felt around the water pump on top of the opti and it was dry.....is there anyway he could make it to my house from his moms ?...its about 80 miles or so
Jamie
Old Nov 18, 2006 | 10:19 PM
lefoy84's Avatar
lefoy84
If it's only leaking a few drops it should be OK!
Old Nov 18, 2006 | 10:25 PM
JH23's Avatar
JH23
yeah its definately not much at all.....under the car on the cross member there was 4 maybe 5 drops...where it had dropped on his carport was about as big around as a 50 cent peice or so...so he should be fine for about 80 miles or so ?
Jamie
Old Nov 18, 2006 | 10:34 PM
JH23's Avatar
JH23
also he replaced it about 40,000 miles ago...any chance it could be a little loose or something ?...i've never had the problem so i have no clue
Jamie
Old Nov 18, 2006 | 11:21 PM
JH23's Avatar
JH23
...can you actually see the opti wet if its leaking down on it or whatever ?....anybody else care to chime in ?
Jamie
Old Nov 18, 2006 | 11:28 PM
Idareu's Avatar
Idareu
Only a 50 cent piece size puddle isn't anything to worry about right now. He would be fine driving it home. Just keep an eye on the temps.
Nah not loose, if it's coming from the weep hole then there isn't anything that could be "loose" that would cause that. It is possible that his water pump is starting to go south but at this point it doesn't sound like it's a critical repair right now judging by the minimal coolant loss. Mine did that for about a year until it finally got bad enough to drip onto the serpentine belt and slinging it on the underside of my hood.
Old Nov 18, 2006 | 11:46 PM
JH23's Avatar
JH23
thanks idareu...man you seem to always be there when i get to asking questions...so a big to you my friend...i guess i'll call him in the morning and tell him to try and get it over here and we'll see what we can find out...we was looking at it with flash lights so tomorrow willbe much better...i just hope he dont break down in it.....hopefully he can make it
Jamie
To water pump question
