Replacing window sweeps?
Old Nov 21, 2006 | 01:02 PM
Ericsvette's Avatar
Ericsvette
Default Replacing window sweeps?
I'm going to be replacing the window sweeps on both doors, Will a right angle rivet gun work or do I need one with an adjustable head?
Old Nov 21, 2006 | 01:14 PM
thebeerman's Avatar
thebeerman
I used my regular old right angle gun, worked fine as long as you are careful. You will have to drop the glass as stated in the helms, but that was also a piece of cake as long as you remember to mark the locations before you drop the glass. It is around a 4 hour job for both, but then I don't work by the hour, and I added an extra layer of sound deadner between the glass and outside door.
Old Nov 21, 2006 | 01:20 PM
Bob CTS's Avatar
Bob CTS
Should be fine with that rivet gun.
To Replacing window sweeps?
