Cold Weather affecting car?
Old Nov 22, 2006 | 10:25 AM
pr1mu5's Avatar
pr1mu5
Default Cold Weather affecting car?
I've never driven my car in below 60 degree weather here in South Florida, and now we have this cold front (relative to SoFla, anyway) ... it's about 45 degrees in the morning, and I notice my car isn't liking it much.
The shifter seems to be a lot tighter, getting it into gears takes a little more encouragement, the clutch seems to be a little stiffer as well. This normal for a 20-30 degree drop in normal environmental temperature, or do I have another problem coming up in the future?
Old Nov 22, 2006 | 10:30 AM
aminnich's Avatar
aminnich
Normal, fluids are a little thicker when chilly. Bet you hear rattles and squeaks you never heard before as well.
Old Nov 22, 2006 | 10:35 AM
pr1mu5's Avatar
pr1mu5
Yeah, a few more rattles and squeaks, mostly from the targa top, and maybe some from the suspension down underneath somewhere...
Old Nov 22, 2006 | 10:37 AM
Bigredwing's Avatar
Bigredwing
How old is your battery? Cold weather can be a killer. Also check your tire pressures.
Old Nov 22, 2006 | 10:39 AM
zo1boy's Avatar
zo1boy
All I know is my car LOVED the cold air this morning!!!
Old Nov 22, 2006 | 12:12 PM
CMYC4GO's Avatar
CMYC4GO
You oughta drive a C4 when the temp is hovering around a balmy 0 F.
The noises the car makes will scare you half to death.
Old Nov 22, 2006 | 12:33 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
In the cold everything gets tighter and some things even disappear......... My cars all seem to like the cold though after they've been warmed up a bit.
Old Nov 22, 2006 | 01:03 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
!!!!!NEWS FLASH!!!!!!
45 degrees F isn't cold.
That's sun bathing weather around here. I might jump in the pool.
Old Nov 22, 2006 | 06:02 PM
oldtimer's Avatar
oldtimer
Vettes were designed to operate in all weather conditions. Here in Missouri I drive mine all winter except when it snows /freezing rain.
Old Nov 22, 2006 | 06:10 PM
BigDR's Avatar
BigDR
Default LT4 + Cold Air = FUN
My car loves cold air. My tires feel like four square blocks for the first mile or two, but after that it's good - very good.
Old Nov 22, 2006 | 06:21 PM
murraybob's Avatar
murraybob
Welcome to the real world of cold weather driving. It takes a while for everything in the car to warm up, but when it does then it will feel normal.
Old Nov 22, 2006 | 06:24 PM
tbone42's Avatar
tbone42
And man do they like sucking in that nice cool air. Let her warm up and you will see Tbone
Old Nov 22, 2006 | 07:06 PM
mikeb's Avatar
mikeb
My FIL just called from Central Fl (Leesburg).
It's actually warmer here than there.
Upper 60's tomorrow.
Last year, 20 degrees and 4" snow. Must be Global (except for Fl) warming.
Ha!!
Old Nov 22, 2006 | 07:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Tires gardually lose anyway but a 30deg F drop in air temp will be seen as a noticible inflation drop too.
Old Nov 22, 2006 | 08:39 PM
RRT vette's Avatar
RRT vette
Normal.
Old Nov 22, 2006 | 10:04 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Originally Posted by CMYC5GO
You oughta drive a C4 when the temp is hovering around a balmy 0 F. The noises the car makes will scare you half to death.
Ah, but the engine is so happy...
Old Nov 23, 2006 | 04:44 AM
RetroTA's Avatar
RetroTA
To Cold Weather affecting car?
Old Nov 23, 2006 | 04:45 AM
RetroTA's Avatar
RetroTA
Ha!!
FIL?
Old Nov 23, 2006 | 06:08 AM
RRT vette's Avatar
RRT vette
Originally Posted by RetroTA
FIL?
I guessing Father-In-Law.
Old Nov 23, 2006 | 06:27 AM
Alzado77's Avatar
Alzado77
I had the same problem with it going into gear a little harder when it was cold. Turned out the clutch fluid was low and whenever it was cold it caused the fluid level to decrease just enough to make shifting hard. Filled it up and it fixed the problem.
