!!another Dumb Question!!
Old Nov 28, 2006 | 07:52 PM
Poncho C4's Avatar
Poncho C4
Default !!another Dumb Question!!
I just received my new seat covers, they came with the
shoulder straps and automatic shift boot!! and my question
is, how do you change the shift boot on my 84 automatic????
Thanks in Advance........Poncho.
Old Nov 28, 2006 | 09:48 PM
Travis93's Avatar
Travis93
To change the shift boot on my 93 you have to remove the center console and it unscrews from underneath I bet yours is the same way.
Old Nov 28, 2006 | 11:13 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
first pop the button off of the stick, use a small screwdriver. then take out the ring holding the **** on. slide off ****. the only reason that you have to get that off is to fit the console over the top. if you dont it will scratch it up... ask me how i know
now you have to take off the panel, to get it off you have to take off the panel with the radio. and to get that one you have to loosen the one infront of the wheel.
then you can unbolt the boot and slide it off. it is easy and i did my '84 auto in about 15min.
good luck, if you need more details or anything just ask
Old Nov 29, 2006 | 06:47 AM
ogres84's Avatar
ogres84
This link might help you
http://www.redlinegoods.com/C4install.shtm#8489
This shows a manual trans, but it's pretty much the same procedure..Just be careful removing the snap ring inside the shift ****, they FLY !!
Old Nov 29, 2006 | 08:03 PM
Poncho C4's Avatar
Poncho C4
I want to to thank....Travis93...ogres84...Corvette form Life.
for their input to my question! Thanks Guy's,
Old Dec 2, 2006 | 06:18 AM
ogres84's Avatar
ogres84
My pleasure, hope my 2 cents helped
To !!another Dumb Question!!
