Wierd Gremlin...
Old Nov 29, 2006 | 03:30 AM
Shawn_65's Avatar
Shawn_65
Default Wierd Gremlin...
So.. this has happened twice in a row right after washing my car at one of those self wash things.. All I do is spray it down and wipe with my microfiber mit... but I might be getting something too wet..like the battery?
Right when I start it up the "Check Guages" light comes on but all the guages are fine..Could this be indicating an almost dead battery?
it takes about 3 hours to clear by sitting(drying?) and the second time it kind of faded when I rev'd it a little. then it finally went away and it never comes back on until I wash my car again.. ???
I'm also running rich so I wonder if its a wierd oil pressure thats throwing this, or just loose wiring.. I dont know! ahh.. it runs fine though, its just a gas hog...
Maybe its the Coolant sensor?
1990 L98, any Ideas guys?
Old Nov 30, 2006 | 12:25 AM
Shawn_65's Avatar
Shawn_65
ttt
Old Nov 30, 2006 | 02:20 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Do you have any codes from anytime recently? The check gauges light wont set any as far as i know, but its hard to point a finger with nothing to point it at. You could change the battery and see if that does it, but i would think it might be more likely to be a ground connection or negative terminal that may be abit dirty
What reason do you have to believe its running rich?
Old Nov 30, 2006 | 02:31 AM
Shawn_65's Avatar
Shawn_65
poor gas milage and occasionaly it smells like rotten eggs.. not often though, I really do needa scanner..
I guess when I took my '90 in for injectors and a tune-up they scanned a code 45.. Rich exhuast. Not sure if thats correct or not..
I cant seem to get any codes right now...
Old Nov 30, 2006 | 03:14 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Rotten egg smell is an indicator that a catalytic converter is going bad...
Old Nov 30, 2006 | 03:27 PM
aminnich's Avatar
aminnich
Also the smell you get from an overcharged or shorted out battery that is 'cooking' inside. If you have a lot of crud on the battery and that crud gets wet it makes a path between the terminals, basically shorting out the battery. It would be rare for 'wet crud' to do any damage, but as they say 'sheet happens'.
Old Dec 1, 2006 | 03:13 AM
86PACER's Avatar
86PACER
Or that you need to lay off the burritos. Just kidding.
A plugged cat will glow. Easier to check for this at night.
Old Dec 2, 2006 | 04:08 AM
Shawn_65's Avatar
Shawn_65
Thanks guys
Old Dec 2, 2006 | 05:53 AM
RRT vette's Avatar
RRT vette
If you are running rich it will ruin the catalytic converter. The smell plus if it glow along with decrease in acceleration usually point to a bad/plugged cat.
Old Feb 28, 2007 | 03:32 PM
jhammons01's Avatar
jhammons01
This thread is only a year old so, I'll Hijack it with the Term Rotten Egg.
I have heard this often, I'd just like confirmation on the Bad Cat issue.
Good Battery.......22 year old Cat.......Rotten Egg smell....only occasionally = bad Cat?
Old Feb 28, 2007 | 04:19 PM
CSS996's Avatar
CSS996
Another wierd Gremlin...
Old Feb 28, 2007 | 06:51 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Look also at teh MAF burnoff relay....My Z28 won't even start, and when it does, it's rough until that relay
is completely dry...
Old Feb 28, 2007 | 10:24 PM
jhammons01's Avatar
jhammons01
Wait, go down that path one more time.....
To Wierd Gremlin...
