1991 Emissions Label, (HELP)
Old Dec 1, 2006 | 07:46 PM
LS6 Motor's Avatar
LS6 Motor
Default 1991 Emissions Label, (HELP)
Does anyone have a 1991, Automatic, non-California car??? I need either a very close up, high resolution picture of the label, or possibly one that was scanned. That would be difficult because you would almost have to remove the upper shroud, but seeing as though it is winter in some parts, I thought maybe someone had the shroud off for some radiator/condenser work.
I was able to reproduce the Supplemental Inflation Restraint, and Belt, label, but I need the Emissions label. Any help would be greatly appreciated. THANKS........
Old Dec 2, 2006 | 08:11 AM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
I have the same year and AT, and a digital camera. I'll give it s shot later today. My only problem is posting the picture on this site. I know that I can email a picture, but it is larger when I do so. I'll get your email address from your profile and sent it later today or in the PM.
Somehow we can make this happen.
SAVE THE SAVE!
Old Dec 2, 2006 | 08:46 AM
LS6 Motor's Avatar
LS6 Motor
Thanks Vetteman, if you ever need the Belt, or Supplemetal Restraint label, I can set you up. I have those two scanned in with my graphic artist, so I can make copies anytime I need to.
Also, what I use is Photobucket.com, and if you go to that website, and type in Kodavette, you will see all my pictures. This is what I'm using for an album.
As far as posting, you just click on the picture, then right click on properties, then highlight the web address, then right click on copy. When posting on this site, it's easy, [img]paste web address[/img]
Old Dec 2, 2006 | 01:30 PM
vetteman42's Avatar
vetteman42
Email just sent ....not sure if it got thru..please advise
Charlie
Old Dec 3, 2006 | 11:27 AM
LS6 Motor's Avatar
LS6 Motor
Thanks to Vetteman for helping me out with the emission label for my car. His digital camera has been working overtime the last couple of days........
To 1991 Emissions Label, (HELP)
