Pretty weird coolant temp
Old Dec 6, 2006 | 10:37 AM
dheiser's Avatar
dheiser
Default Pretty weird coolant temp
This is pretty wild! I'm drinin' anround in my '94 vert yesterday, OAT is 60+ and I'm watching my coolant temp gradually rise to about 250 on the gauge. WOW, scary!! The other odd thing; the fans didn't come on until it got around that same temp! I hurry home, keep it running in the garage and use my infrared thermometer to verrify the temp.
The thermometer could not fine a temp above 200-205 anywhere, on the intake near the thermostat housing or return hose to the rad. The engine wasn't showing any other indications of overheating (rough idle, acceleration).
I've seen this happen one other time, but mostly the indication is normal about 190-200.
Is this a bad temp sensor? I can't see that it's the 'stat because of the manual temp indications.
Lookin' or help. thanks.
Old Dec 6, 2006 | 10:42 AM
RRT vette's Avatar
RRT vette
Which coolant temp guage were you looking at....digital or analog? Both temps come from different sensors/senders. One in the head (analog) and one in the waterpump (digital).
Were both showing the same temp???
Old Dec 6, 2006 | 10:44 AM
dheiser's Avatar
dheiser
I was looking at the analog gauge. Excuse my ignorance, where is the digital dispay??
Old Dec 6, 2006 | 10:45 AM
scranage's Avatar
scranage
I've seen that analog get really high with air trapped in the system.
Old Dec 6, 2006 | 10:46 AM
scranage's Avatar
scranage
Press the gauges button till coolant temp comes up in the center of the dash. I usually find I have to bleed my system several times to get all the air out after working on it.
Old Dec 6, 2006 | 10:48 AM
RRT vette's Avatar
RRT vette
You can use the guages button to scroll through the oil temp, coolant temp, ect. It will display where the mileage shows.
On my 95 I never rely on the analog guage. The needle might be in the hash marks, but the digital guage will show 200*. Next time watch the digital when the analog is showing hot.
Old Dec 6, 2006 | 10:55 AM
dheiser's Avatar
dheiser
Thanks for this info. I've had my 'vette for about 6 weeks and still learnin'.
There hasn't been a whole lot of good cruisin' weather here. It sucks getting a new toy this time of year.
Old Dec 6, 2006 | 10:57 AM
RRT vette's Avatar
RRT vette
These cars are a different animal. I like the red vert.
Also the fans will come on when the A/C is turned on. The PCM controls the on/off temps for the fans. Usually 227* they will come on and 217* they will go off. Good idea to let it idle while you observe the on/off temps.
Old Dec 11, 2006 | 04:34 PM
03blackburb's Avatar
03blackburb
With the AC off, should both fans come on about 227* or just the one?
Old Dec 11, 2006 | 04:50 PM
RRT vette's Avatar
RRT vette
Both of mine do on my 95.
To Pretty weird coolant temp
