Powder coating wheels?
Old Dec 14, 2006 | 02:03 PM
F1Fan's Avatar
F1Fan
Default Powder coating wheels?
I've got a set of silver aftermarket Grandsport wheels that I'd like to powdercoat black to look just like the '96 GS wheels. I really don't know very much about powder coating, other than it's baked on and durable.
So I've got a couple questions:
What I'm concerned about is getting that machined lip to look correct, and what about tire mounting? Am I likely to be getting chipped wheels back after the tires are mounted? Any special machine I should look for a place to have to mount them w/out possible damage?
And any suggestions as to who/where could do a set of wheels like that? I'm in Louisville, KY if someone knows anything nearby me, I'm not adverse to shipping them if need be though.
Thanks!
Old Dec 14, 2006 | 02:11 PM
KCHOTBOAT's Avatar
KCHOTBOAT
Any decent shop should be able to do a nice job masking the lip for powder coating. corvette pilot is a sponsor and does powder coating. Not sure if he set up to do wheels. I no longer have my powder coating setup so I plan on doing mine this winter at a friends shop.
Here is a link to some of his work.
Old Dec 14, 2006 | 02:14 PM
KCHOTBOAT's Avatar
KCHOTBOAT
http://forums.corvetteforum.com/show....php?t=1573044
Old Dec 14, 2006 | 02:39 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I understand you can also do the powder coating yourself, just bak the wheels in an oven. Of course then you'll have to buy something REAL NICE for the wife.
Old Dec 14, 2006 | 04:59 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
If you bake em in your kitchen oven yer gonna be buying her a nice new oven as well as a gift.
An oven used for powder coating can not be used after that for food preparation.
Old Dec 14, 2006 | 06:34 PM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
Thanks!
I have powdercoated wheels and they have not been chipped from having tires mounted.
But, make sure to use the weights that go on the inside of the rim. If they mount them on the lip, it will chip for sure.
Rik
Old Dec 15, 2006 | 01:02 AM
KCHOTBOAT's Avatar
KCHOTBOAT
You can never use the oven for anything else again like stated. To do it yourself you need a oven, clean dry air, gun and powder that would be the basics. You will need to build a booth or buy one also if you want your parts to look nice. You will need to prep the wheels also. I you are planning on doing more parts it may be worth buying the equipment for you. I had alot of fun doing it and made some money off of it. I gave it up because we moved to a new house and I want to do alot of things to the car. I started with a toaster oven and by the time I sold my stuff I had to small ovens, 4 guns, blasting cabinet tons of over things. There are tons of hoppy powder coating forums and if you want the links I can sent them to you. Powder coating is easier to learn the wet paint, however it still has takes practice and doing your wheels would not be a good place to start right away.
Old Dec 15, 2006 | 01:06 AM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
How much should one expect to pay for a coating job on four wheels?
Old Dec 15, 2006 | 01:15 AM
KCHOTBOAT's Avatar
KCHOTBOAT
Depends on the prep for one thing and your area. A friend of mine charges $45.00 a wheel to coat a single stage basic color. He charges $85.00 an hour to blast if needed. A wheel place here in town charges $100.00 a wheel which I feel is way to much for my area.
Old Dec 15, 2006 | 01:19 AM
KCHOTBOAT's Avatar
KCHOTBOAT
PM corvette pilot and see if he is set up to do wheels. I have seen alot of pictures of his work and everything looks great.
Old Dec 15, 2006 | 08:52 AM
440man's Avatar
440man
Kchotboat, I would be interested in those powder coating forums you were talking about. Would you post them or PM them to me.
Old Dec 15, 2006 | 09:26 AM
F1Fan's Avatar
F1Fan
Thanks for all the info guys, I'm interested in those links too.
I'm tempted to pick up a old used oven and try it, but I don't actually have a 220v line laying around the garage I could easily tap into, but I'm sure thats good advice about trying it on some other things first.
Another question, my wheels are painted silver, and I think with maybe a layer of clear on top. They've got alot of brake dust damage to the insides. Would it be better to get them media blasted, or is there a dip or anything better/easier to use to get it down to clean metal rather than media blasting?
And I was worried that the PC seems thick enough that I was afraid masking the machined lip would be tough to do, and to remove. But maybe the thing is to remove any masking before you bake it?
Old Dec 15, 2006 | 12:10 PM
Ian94's Avatar
Ian94
I had my wheels on my 94 powdercoated, cost about $80 a wheel, that was for blasting and coating. Had it done at a shop here in Tulsa. They were able to tape off the rim edge, looked very good, I was pleased with it. As someone already mentioned, when you balance them, you need to have the stick on weights put on. There were no issues mounting the tires, no scuffs or anything.
I'd post a pic if someone tells me how to do that....
Thanks,
-Ian94
Old Dec 15, 2006 | 01:54 PM
thebeerman's Avatar
thebeerman
The pc should run around 100-150 for all four. Make sure you have them cleaned and ready to go. The shop I took mine to bead blasted them first, then I polished them, and had them cleared. The tire shop was informed, and took extra care when mounting to not damage the pc, and the weights are on the back. By the way, have them coat the entire wheel, inside, back, etc. That way the coating can't get loose (chemicals work their way under the coating).
Jims79's Avatar
Jims79
I power coated a set of rallies black. Looked great & mounting the tires did not chip or scratch them. I paid $25 a wheel total was @ $130.00
Old Dec 15, 2006 | 05:23 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Give these guys a call for a quote:http://forums.corvetteforum.com/show....php?t=1570907
To Powder coating wheels?
