Flat Tire
Old Dec 20, 2006 | 11:19 AM
vettetown's Avatar
vettetown
Default Flat Tire
Ok I got a flat tire on 90 corvette, I personally do not have a jack or anything to take the wheel off. Does the car have the tools somewhere hidden under the car im guessing?
Old Dec 20, 2006 | 11:21 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Rear passenger compartment under the tray
Old Dec 20, 2006 | 11:27 AM
Wayne88's Avatar
Wayne88
My '88 has the factory jack with the spare tire.
Old Dec 20, 2006 | 11:28 AM
All2kool's Avatar
All2kool
The Jack is with the Spare, in the back. You do know where the Spare is right?
Old Dec 20, 2006 | 11:39 AM
Wayne88's Avatar
Wayne88
Then its the same as my '88. The lug nut wrench should be behind the drivers seat. Use it to undo the spare tire carrier, the jack should be with the spare.
Old Dec 20, 2006 | 11:46 AM
c4cruiser's Avatar
c4cruiser
One of the most important thing to learn about a C4 is how to change a flat tire and mount the spare There should be a decal with tire changing instruction under the lid of the passenger side storage compartment.
Depending on the year of the car, the jack can be at the bottom of the passenger side storage compartment or in a bag attached to the spare tire that is in the carrier under the rear end. The factory lug wrench (such as it is ) will be either behind the driver's seat or in the storage compartment depending on the year.
There is a bolt below and behind the rear license plate that you loosen to lower the spare tire. You will also have a small lamp that lights up with the interior lights so that you can see at night.
The spare tire is probably the most neglected part of a C4. It's out of sight and flat tires are uncommon anymore so there is no real impetus to check the spare until you really need it. The chances are pretty good that the spare will not have any air in or nowhere near enough air to be useable. It needs 60psi to be able to run at the designated 50MPH for short distances.
Place the jack on the lower body rocker panel between the two molded arrows on the bottom edge. Thee are two sets of arrows for the front and rear. Raise the car carefully and swap the tires.
The spare tire tub will accomodate up to a 285/40-17 tire and wheel but a 315/35 tire will not fit. There are two notches on the front of the tub that allows the tub to lower enough to insert the road tire.
Old Dec 20, 2006 | 11:53 AM
All2kool's Avatar
All2kool
Also, there are two positions for the hanger at the license plate, the second position being for stowing a regular size tire.
Old Dec 20, 2006 | 11:54 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Same on the '96.
Larry
code5coupe
Old Dec 20, 2006 | 02:20 PM
Goldcylon's Avatar
Goldcylon
Default re:Wheres the jack on my 90
Yep mine is in a factory sleeve bag that clips down ontop of the spare. You wont see it until you drop the spare donut wheel. The lug wrench is behind the drivers seat under a factory hold-down clamp on top of the rear seat rail mounts. And your factory wheel lock should be in console rear area with a clip mount as well. I have a 90 so I will make the bold assumption yours will be the same.
Bit of advise it easier to reinstall the donut when you done with it by removing the rear license plate. Gives you a better view. Goldcylon
To Flat Tire
