PF 52 Filter???
Old Dec 21, 2006 | 01:08 PM
MyOtherCar's Avatar
MyOtherCar
Veteran: Marine Corps
Default PF 52 Filter???
Does anyone know if the PF52 filter is a sutable substitute for the PF 51 for the LT1?
TIA
Old Dec 21, 2006 | 01:37 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
My 1996 owners manual lists the PF52 as the recommended filter.
Old Dec 21, 2006 | 02:42 PM
MyOtherCar's Avatar
MyOtherCar
Thanks, appreciate you doing a double check for me. I kind of thought it was the correct one, or an alternate to the PF51, but wasn't 100%
Seems I remember something in the Forum that the PF52's are not being mfg'ed any longer.
Anyway, planets are aligned again... Thanks
Old Dec 21, 2006 | 02:54 PM
Gixster's Avatar
Gixster
I wish I could remember the filter number. I'll have to check when I get home. I picked up a filter for my LT1 at the Chevrolet dealer a while back. It was a different number than what I had been using, and I was told it was a superceded number. Fine.
Well, when I got home and drained the oil/filter, I discovered that this superceded part had a larger thread diameter than the old filter or what the motor would accept. Oops.
I'll look when I get home tonight and post up the number. I still have it.
Old Dec 22, 2006 | 12:29 AM
CE1's Avatar
CE1
I use the PF1218 on my LT1 in the Camaro for extra filtering, replaces the PF35. Standard was the old PF25, not sure of it's replacement No. Use the PF52 on the LT4 in the Vette, No problem finding them.
Old Dec 22, 2006 | 01:03 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The PF51 was replaced by the PF52. I had it on both vettes and my truck, but now two trucks later, I have a different filter for it.
Was so much easier buying one grade of oil and one filter for all three vehicles.
Old Dec 22, 2006 | 08:30 AM
MyOtherCar's Avatar
MyOtherCar
PF52 it is, much thanks for your replies
Old Dec 22, 2006 | 09:40 AM
Strick's Avatar
Strick
I bought a case of UPF-52 a few years ago. Works fine with the Mobil 1. They are supposed to be a little better than just the PF-52.
To PF 52 Filter???
