Which New Tires?
In fact, treadwear would be my LAST consideration............
For most of us, a Corvette's tires will get old, hard, and slippery long before they wear out from street use....so we'd be replacing the tire before we saw all the tread life the tire is capable of anyway.
They both have a traction rating of AA, yet one has a treadwear rating of 320 and one has 220?? Tell us what tires you are talking about and you'll get more opinions.
My own opinon?
Just forget the treadwear rating and get the tire you like the best.
Larry
code5coupe
When comparing one manufacturers tire to another's, it is much less reliable a determining factor. But yes generally speaking, you can expect a rating of 320 to last longer than a rating of 220. How much longer is probably more dependent upon the way you drive than the actual rating. And yes, generally speaking, the lower the number, the more grip the tire will normally exhibit over a like tire with a higher number.
If you go to The Tire Rack website, you will find a section that talks all about the different ratings of tires, to include tread wear. Great information and you will come away a much better informed consumer.
Good luck... GUSTO
