Removing rear quarters
Old Jan 4, 2007 | 07:03 PM
BAM92's Avatar
BAM92
Default Removing rear quarters
How hard is it to remove quarters and reinstall on another car. Basically seeing if it is worth buying a wrecked ZR1 just for the rear half. The doors, rockers, wheel wells are easy just wondering about the quarters and related bonded parts. Thanks.
Old Jan 5, 2007 | 05:47 PM
JackDidley's Avatar
JackDidley
Unbolt the back bumper stuff and use a sharp wood chisel to seperate the bonded areas. Installing is a little more technical.
Old Jan 5, 2007 | 06:12 PM
93-383's Avatar
93-383
if the wrecked zr1 still has its LT5 then hell yes
Old Jan 5, 2007 | 07:31 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It''s hard to get it off without damaging the quarters. If you do this, make sure you get EVERYTHING! None of those parts are available except at ridiculous prices (fender molding-$500).
Old Jan 6, 2007 | 08:25 PM
BAM92's Avatar
BAM92
It is just a shell doors back. Thanks for the heads up on the molding. It is not on it. Definetly need to take that into consideration.
Old Jan 6, 2007 | 11:14 PM
zr1fred's Avatar
zr1fred
Actually I meant the rear bumper molding. The bumpers are outrageous too!
Old Jan 7, 2007 | 04:27 AM
BAM92's Avatar
BAM92
Found the rear bumper molding for 200 used. Rear bumper is 500.
To Removing rear quarters
