Charging Problem?
Old Jan 8, 2007 | 04:05 PM
yn1bennett's Avatar
yn1bennett
Default Charging Problem?
I had a weak battery and just replaced it. Now, all of my lights, the headlights, dash lights, interior lights, etc are all blinking like a strobe or pulsating. I was told by a friend that I need to replace the alternator now because it looks as though the regulator in the alternator has gone bad.
Is this right? The alternator is putting voltage out, but above the 14.0 volts as normal. It will range from 15.9 down to 13.8.
This is a 1984 Vette.
Old Jan 8, 2007 | 04:11 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Did you do a test on the battery? also Did you do a test on the volt output of the alt to the battery? if not, i would check that first to see if your alt is putting out voltage or take the alt to napa, a parts store and have it check....
Old Jan 8, 2007 | 09:35 PM
jfb's Avatar
jfb
Most likely you have an oscillating voltage regulator in your alternator. Engine idling and lights blinking, unplug the connector on the alternator and see if the blinking stops. If it does, you can replace the voltage regulator, have an auto electrical shop replace the voltage regulator or replace the alternator, in that order of expense.
Don't bother taking your alternator to a parts store to test because they can not test for an oscillating voltage regulator.
Old Jan 9, 2007 | 10:33 AM
yn1bennett's Avatar
yn1bennett
Thanks for the input. I have a new alternator on order. $85.00. Hope this will sovlve problem.
Old Jan 9, 2007 | 02:18 PM
f451degrees's Avatar
f451degrees
remember to fully charge your battery before running your new alternator, or you may fry it.
see ya on the road
Old Jan 12, 2007 | 03:27 PM
yn1bennett's Avatar
yn1bennett
Just got my new Alternator in last night and exchanged it. Now, all of my lights are not blinking like before. Charging adverage of 14 volts. Good to go. Thanks for all of the input I had. This forum is awsome!!
To Charging Problem?
