harmonic balancer?
Old Jan 14, 2007 | 02:13 PM
92lt1vet's Avatar
92lt1vet
Default harmonic balancer?
working on my 92 lt2 but cant get the balancer off even using a heavy duty air impact, any tips or tricks to help ? thanks
Old Jan 14, 2007 | 02:22 PM
STL94LT1's Avatar
STL94LT1
Are you trying to remove the balancer or hub? To get the balancer off you need to remove the three bolts and tap it from underneath. The hub will need a puller to remove.
Old Jan 14, 2007 | 03:39 PM
92lt1vet's Avatar
92lt1vet
just trying to pull off the balancer off so that i can do the tune up on it /opti spark
Old Jan 14, 2007 | 03:44 PM
STL94LT1's Avatar
STL94LT1
It's probably rusted on. Remove the three bolts. Then get under the car and tap/beat it forward. Hit it with something soft, wood, rubber, ect, not to damage.
Old Jan 14, 2007 | 04:03 PM
92lt1vet's Avatar
92lt1vet
thanks ill give it a shot, i hope it works mike
To harmonic balancer?
